Oil Archive (no new posts) An archive of oil related questions and comments.
Amsoil how long inbetween changes
Old 06-06-2009 | 02:05 PM
goblish's Avatar
goblish
Default Amsoil how long inbetween changes
I am coming up to my first oil change on my 09' fatboy and 5000 mile mark on the wifes 08' fatboy and I am going to switch to all amsoil in all three holes. So my question is I have heard you can go twice the oil change intervals as harley oil so how long do you guys go 3000 miles or more. Thanks for any imput.
Old 06-06-2009 | 03:55 PM
dalegalbraith's Avatar
dalegalbraith
6th Gear
I go between 5 to 7k between oil changes in the engine. Primary and tranny every second oil change 10 to 15k.
Old 06-06-2009 | 04:28 PM
ko4qc's Avatar
ko4qc
I know its overkill but I change all fluids(except brake) around 3k...
Old 06-06-2009 | 10:33 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
With Amsoil;
Engine: 5000
Primary: 5000
Trans: 15-20,000 (if you use the Amsoil 75w110 or 75w140 gear oil)
Old 06-06-2009 | 11:39 PM
nocarb's Avatar
nocarb
I go 5,000 miles and get a UOA and oil still has plenty of life left. If you wanted to go further it can but I would not without a UOA.
Old 06-06-2009 | 11:44 PM
JayStronghawk's Avatar
JayStronghawk
5,000 Miles all three not that big a hassle to change fluids.. Amsoil 20W50 Engine and Primary, 75W110 in the Tranny although considering Spectro GL-5 for 6 Speeds next change...
Old 06-07-2009 | 08:21 AM
dalegalbraith
6th Gear
Amsoil 75-110 Severe Gear synthetic.
Old 06-07-2009 | 08:24 AM
Notgrownup's Avatar
Notgrownup
5-8k engine, 10K primary 20k tens...20w50 all 3...will go to gear oil next change.
Old 06-07-2009 | 10:21 PM
garyhendley's Avatar
garyhendley
5000 on the motor and primary 10000 on the tranny-ride safe
Old 06-08-2009 | 10:10 AM
Heath's Avatar
Heath
Former Sponsor
Twice the interval is what you can do. Do many do it..probably not. Too much fun changing the oil at least twice a season
Most OEM intervals now say 5000 so you could run it to 10K if you so desired. If the goal is to run those extended intervals, then for piece of mind and to be sure everything is performing well, I'd do an OA at 5-6k and see how it's doing. Then you'll feel better about the intervals you are running.
Heath
Lemms
04-28-2015 05:15 PM
fireaxxe
11-20-2010 01:23 PM
05 HD Deluxe
05-12-2007 03:36 AM
wildfire
09-05-2006 04:49 PM
Phantomryder
06-01-2005 06:46 PM
Quick Reply: Amsoil how long inbetween changes
