Oil Archive (no new posts) An archive of oil related questions and comments.
Oil Quanity
Old 05-28-2009, 04:31 PM
whitrt's Avatar
whitrt
whitrt is offline
Default Oil Quanity
Service Manual saids 3.5 quarts of oil in the engine. My friend says he always just uses 4 quarts. Any bad effects of having .5 quart too much oil in the crank? Who uses 4 quarts and who uses less?
Old 05-28-2009, 05:47 PM
Pine Tree's Avatar
Pine Tree
Pine Tree is offline
MODERATOR
Received 1,964 Likes on 463 Posts
My '08 will spit oil into the air cleaner until the hot level drops to about mid dipstick. So now I just fill hot to that level and eliminate the oil mess...
Old 05-28-2009, 06:00 PM
RCB's Avatar
RCB
RCB is offline
I always follow the service manual and have never had any problems with oil in air cleaner.
Old 05-28-2009, 07:30 PM
dawg's Avatar
dawg
dawg is offline
Received 3,222 Likes on 1,839 Posts
Service manual for the 09 says 3.5 quarts (initially). The maintenance specifications for the 09's (as in years past) state 4 quarts. You will be fine with 4 quarts. However, as others stated you risk some blowby. I always run 3.5-3.8 quarts to lessen the chance.
Old 05-29-2009, 08:58 AM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
Many guys on here dump in 4 qts and call it good. Of course there are a few who like getting an oil bath because it is probably the only bath they get every once in a while....
Old 05-29-2009, 12:47 PM
stevent's Avatar
stevent
stevent is offline
4 qt's in the engine, 1 qt in the primary and 1 qt in the transmission works on my stock '08. No blow by no muss no fuss...
Old 06-24-2009, 10:37 AM
tgaetto's Avatar
tgaetto
tgaetto is offline
So I had this long saga on the oil, fixed a few problems did an oil change put in 3.8 qts in and came off some traffic and hammered it of a stop sign after sitting and blew oil all over my brother and his bike (good thing it was a rental) I have had this happen 2 other times.
The problem I have is I am not sure where Happy is with my bike since I had a consistent leak until recently. I pulled the rear plug and it had a lot of oil but I think the breather is the cause. I am going to reroute the breather today finally as time has not allowed sooner.
We shall see what happens? How much is normal on the breather venting oil??
Old 06-24-2009, 07:20 PM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
4 qts. for mine.
Old 06-24-2009, 07:46 PM
xxxflhrci's Avatar
xxxflhrci
xxxflhrci is offline
Been dumping 4 quarts for 75k miles now. Never had an oil left leg.
Old 06-25-2009, 02:38 AM
emwolb's Avatar
emwolb
emwolb is offline
xxxflhrci, wouldn't you be oiling your right leg instead, unless you got one of the special edition harleys that has the air cleaner on the left side.
Quick Reply: Oil Quanity
