Diesel Oil in bike...
RE: Diesel Oil in bike...
Rick - it was just a word of caution, and you should always watch your oil to see if anything "interesting" comes out... a buddy in high school had a chipped off part of a nut come out in his oil change. The look on his face was priceless But I wasn't trying to say the oil might not work - just saying to keep in mind that you should always be watching the oil when you do an oil change.
Skippy - sounds interesting that he used 15W-40.... what part of the country is this? The water cooled metric probably runs a little cooler than the V Twins... but if it works fine in those for years, why not a Harley? Hate to knock on the factory - but the bar and shield doesn't always mean its worth what your paying for it.
Think I'm going to try and find something around the 50W diesel oil when I get home to run in my bike, something to help hold off against the heat. Anyone from the South have any thoughts on this?
Swede
ORIGINAL: RickGlide
Hi Swede, I'm thinking about using mobil delvac 5-40w that I already use in my vw jetta deisel. For my tc88 oil. What did you mean by "watch out for metal flakes in the oil after next change?" Was that just a caution statement?Thanks Rickglide
Guys......the TC88 engnie cools the pistons by squirting oil on them from underneath and is a KILLER of motor oil. The use of a 40 weight oil will work but will shear down to 30 or even 20 weight pretty quickly. Air cooled MC engines like the TC88 require a very robust oil in them to reduce wear and heat damage caused by friction. Bottom line: You paid a lot of $$ for a nice motorcycle....don't screw the motor using cheap oil where there are group III, IV, and V synthetics out there that will do a better job and give you better performance for $20 more per change. Just my $.02
campdreamer47
Oil Archive (no new posts)
09-16-2007 06:05 PM
