how to change oil in 92 fatty???
i am in the process of changing the oil in my 92 fatty for the first time. i found the plug in the end of the hose under the bike (pretty easy) and found the filter (even easier). is there another drain plug for the crank case that i am not seeing or is the hose with the plug the only drain i have to worry about?
RE: how to change oil in 92 fatty???
I would recommend you get a service manual for your bike if you plan to do any work on it. They run about $50 and are worth every penny. You might consider getting a 3/8 drive inch lb rated torque wrench too.
Received 1,296 Likes
ORIGINAL: KBFXDLI
Call me crazy but I like to torque everything
ORIGINAL: pococj
Yeah, but if you had a Sloptail would you torque the hose clamp on the oil tank dain?
ORIGINAL: KBFXDLI
