oil level on dyna ???
![Question](https://www.hdforums.com/forum/images/icons/icon5.gif)
Engine oil
well i check my oil yesterday hadn't been ridden all week so it was cold as and overfilled acording to manual . when i looked at a mate's level it was was well over the hot mark when it was stone cold .I was going to morgan and wackers ( Harley dealer in Brisbane Australia ) When i told the dude at the service , he ask if i screwed the top all the way in to check i said yes he said well there's ya problem you shouldn't do that , u just stick it in without screwing it in and there's ya reading. The paragraph for hot and cold check says TO screw back all the way in to get a reading .So then i ring M&W Brisbane they tell me that some you do screw all the way in and some u dont so we here at M&W have decided to do all the same way which is not screw in at all.
So what the right way ?? I say by the manual .
does it matter??
if u do 1 way or the other u either have too much or too little oil . Better to have much then to little i gess .
what do you guys say on this matter?
Thanks
Taxi
does it matter??
Thanks
Taxi
The 07 Dyna service manual and owners manual say to screw it in till it stops that is how i have always checked mine hot or cold and have had no issues. Honestly i have never payed much attention to the cold reading when i change the oil i put in 2 1/2 quarts fire up the engine warm it up and check it. I mean i check it cold just to make sure theres oil in there but i always warm the bike up then check it if its full on hot i ride.
Best readings are always hot on the jiffy stand after allowing 4-5 minutes for the oil to return to the tank. I don't screw it in at all. Never a problem. Also, at oil change time 2.5 qts out-2.5 qts back in and the level is always just right.
