Best AND SIMPLEST INSTALL ON flhrc OIL COOLER NEEDE!!
![Question](https://www.hdforums.com/forum/images/icons/icon5.gif)
Help me please. I 'd like a do it yourself simple oil cooler for an 08 FLHRC. What are my options? Do I use HD or an aftermarket kit. HAVE TO GET AT IT ASAP. PLEASE HELP ME. tHANKS, J
![EEK!](https://www.hdforums.com/forum/images/smilies/eek.gif)
The Jagg seems to be the best unit, it has the less pressure drop. Both th HD unit and the Jagg are simple to install. Its as easy as removing the oil filter, screw on the adaptor reinstall oil filter, mont cooler and run the lines.
The hardest part of the install is cleaning up the oil that spilled out of the oil filter.
You dont want it to run below 180, and you should keep it below 250. Mine would get to 250 on hot days in traffic then drop to 220 on the freeway.
With the cooler it gets to about 230 in heavy traffic and 200 - 210 on the freeway. The cooler seems to drop temps about 20-30 degress. That is with the Jagg 10 row cooler and running synthetic oil.
Best
J
cruisingbull
Milwaukee Eight (M8)
06-27-2018 12:31 PM
