Low oil pressure
Low oil pressure
06 ultra classic 3,000 miles. when it gets to highway temp (riding about 20 miles) at idle the oil pressure is very low, almost reading nothing on the gage. Is this normal? is the pump high volume, with low pressure when it's at operating temp's.
Ron
Check it with an external oil pressure guage. You sending unit may be malfunctioning. The biggest indicator you have an oil pressure issue will be engine top end clatter. You may also have a weak bypass valve spring.
I'm guessing here but I suspect the idiot light sendor is in the area of 2-3 lbs when the light will come on. Best solution is to check with a mechanical gauge and see what you really have. If normal with this, your sender is bad, or even the gauge itself
Ron
Ron
Road Star
Engine Mechanical Topics
15
06-30-2016 09:02 AM
