Synthetic too slick??
RE: Synthetic too slick??
ORIGINAL: Curt J
It's true!!!! S&\\;S and Perewitz suggest dino until 10,000 miles and even there after!!! Perewitz Customs used to have a chrome "MOBIL 1" badge on all their engines-No more. Call em, they even recommend running Dino after break in. No BS!!!
Mobil1Vtwin is the official oil for S&\\;S. They announced it 2 years ago.
ORIGINAL: avalauncher
Hope you're right, was planning on switching to it at 1000 miles. According to him, he and a bunch of others attended a HD service session in Nashville (I believe) and when the HD Rep asked how many were pushing syn oil to customers, none replied in the affirmative. When he asked why, was told by many of issues they, the service personnel, are seeing.
Guess they forgot to mention that all the CVO bikes come with Syn3 from the factory. Mobil1 is factory fill for Corvette, Aston Martin, Mercedes, Porsche.. you know all the crap cars with cheap engines.. AND the idiots at Ferrarri put QS Horsepower full synthetic in their lousy engines too... your friend is a dikhead.........
My old RK Evo ran 106k on synthetic oil and the heads were never removed from that bike. It is still running today with >115k at last count.
OK, I'll tell you "maybe" what he was told but misunderstood. (Got it?)
Most engine manufactures do not suggest breaking in a new engine with synthetic. You need for the rings and bearings to seat so in many cases the car, airplane, scooter, tractor does Not have synthetic oil from the factory (even though the MFG says Use Synthetic). After 3 to 5 thousand miles on the break-in oil running synthetic is best. Too slick? Hogwash.
Didn't have to look hard for this. it's off the Amsol site.
Breaking in a new engine is the one area that petroleum oil is better for than synthetics. You see, petroleum oil has a very low film strength which is ideal for breaking in a new engine. That is why we recommend you run the factory installed petroleum oil for about the first 500 miles.
Further heat cycling break-in will continue during the multiple heating and cooling cycles from driving your vehicle under varying RPM and engine load conditions and then shutting it down for a long period of time to let it cool completely. The multiple heating and cooling cycles are a extremely important factor in properly breaking in a new engine and are often an overlooked factor in the total break-in process. These heating and cooling cycles achieve what is called stress relieving. Back in the "old days" of engine manufacturing, after casting and before an engine block was machined, it would be set outside for several months to age, during which stress relieving occurred naturally, then the block was machined, which helped to produce a better engine than one that was machined immediately after casting.
