Oil Archive (no new posts) An archive of oil related questions and comments.
Low Oil light on Ultra
Old 07-11-2008 | 10:07 AM
SPIDER7474's Avatar
SPIDER7474
Stage II
Default Low Oil light on Ultra
05 Ultra with low oil light that flickers on. Might stay off for 100 miles and then flickers on again. Oil pressure is around 32 when it happens. Changed the Low Oil swith on font of engine, but it flickered on again. Can't figure it out since I still have good oil pressure. Could it be electrical? Any answers appreciated.
Old 07-11-2008 | 10:24 AM
lschultz's Avatar
lschultz
Default RE: Low Oil light on Ultra
If you have already changed the low oil switch that probobly was not the cause unless you got lucky and got a bad one. Check the connections on the switch make sure they are clean and making good contact. Could be the wire that goes to the switch shorting out somewhere rubbing on the frame, bad buld in the light. Some of them electrical gremlins can be hard to find.
Old 07-11-2008 | 10:29 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
ORIGINAL: lschultz
&nbsp\\;
+1 I would suspect an electrical short as well if your oil pressure guage is reading 32
Old 07-11-2008 | 01:51 PM
RAMP27's Avatar
RAMP27
6th Gear
Oil pressure light is energized all the way to the sending unit screwed into the crankcase. Sending unit supplies the ground path for the light to go on. Any short to ground upstream from the unit will cause light to come on. I've seen water leak down from the windshield and drip onto the connector going to all the indicator lights on FLT's cause corrosion that provided a ground path. First try running with connector at oil sending unit unplugged for awhile and see if problem repeats. If it doesn't, then sending unit is bad. If it does, then look at indicator light connector, clean it , and apply dielectric grease to it to keep problem from returning.
Old 07-11-2008 | 04:54 PM
SPIDER7474's Avatar
SPIDER7474
Stage II
Thanks, will try it and see what happens.
GZRGLYD
Milwaukee Eight (M8)
11-20-2017 06:36 PM
Flightmast
07-29-2017 03:12 PM
RobertV
01-12-2013 10:53 AM
scooby doo
06-11-2011 06:49 PM
e6fmf
04-26-2008 10:46 PM
Quick Reply: Low Oil light on Ultra
