Oil Archive (no new posts) An archive of oil related questions and comments.
..one more post on OIL
Old 07-20-2013, 08:43 AM
glideridemike's Avatar
glideridemike
glideridemike is offline
I am going to give Amsoil a try this go around. Have been using Mobil V Twin with good results but want to try Amsoil before our next long ride.
  #472
Old 11-18-2013, 04:47 PM
blueridge's Avatar
blueridge
blueridge is offline
Default oil question
hold yer horses! I don't want to beat a already dead idea but do want to ask something. Last time I changed my oil I put Amsoil 20w-50 in all three holes ('12 FXDB) and then I felt a bit more metal rattling than the dealer installed oil. Talked to someone on this forum and they said they would only put heavier weight oil in their tranny. I forgot if some folks out heavy weight oil in their Transmission or Primary? I had a 75w-90 on hand and put it in one of the holes and think it was the transmission. I do not think people put these heavy weight oil in the primary right? Cannot find my notes but want to confirm before I go ahead and change all fluids.
  #473
Old 11-18-2013, 04:52 PM
0lowrider1's Avatar
0lowrider1
0lowrider1 is offline
i put 70-140 gear oil in the tranny and atf in my primary
  #474
Old 11-18-2013, 04:57 PM
blueridge's Avatar
blueridge
now you've thrown something in the mix.
really? aft in the primary? funny thing is HD recommends same 20w-50 in all three holes and I presume they have tested this and recommend this otherwise they'd have a lot of warranty issues.
  #475
DJY's Avatar
DJY
DJY is offline
I use 75 90 in trans.
  #476
Old 11-18-2013, 05:02 PM
Robbie13's Avatar
Robbie13
Robbie13 is offline
LOSER
Old 11-18-2013, 05:04 PM
INJEKTER's Avatar
INJEKTER
INJEKTER is offline
I'VE used Harley's Screaming Eagle synthetic in all three holes.... bike has run flawless for the past 4.5 years.....im no oil guru and don't want to be....works well for me...
  #478
Old 11-18-2013, 05:05 PM
Ridewva's Avatar
Ridewva
Ridewva is offline
I believe 20w-50 engine oil is a heavier viscosity than 75-90 gear oil.
actually they're about the same viscosity https://www.hdforums.com/forum/oil-a...-gear-oil.html
  #479
ghira75's Avatar
ghira75
ghira75 is offline
It had to be the transmission as the oil in the primary is filled through the derby cover.
Check out Spectro, they have a specific oil for the primary chaincase and another for the transmission which is a 75W140 called HeavyDuty platinum 6speed
  #480
Old 11-18-2013, 05:18 PM
marcortez's Avatar
marcortez
marcortez is offline
It only makes sense to put gear oil in gear cases.
However, some swear by a 20-50 motor oil in their gears.
Quick Reply: ..one more post on OIL
Top
© 2024 MH Sub I, LLC dba Internet Brands
Follow Us
