Oil Archive (no new posts) An archive of oil related questions and comments.
oil filters
Old 05-31-2008, 11:13 AM
ardbark's Avatar
ardbark
ardbark is offline
Default oil filters
any one use fram oil filters they have them at advanced auto for 10.00 and in chrome
Old 05-31-2008, 12:50 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
Default RE: oil filters
Fram filters are crap. Paper element, cardboard end caps, crappy ADBV. A HD 5 micron filter with synthetic media is only about $2 more. The Fram filtration level is no good if you have a TC engine. If you want an automotive replacment filter get a Wix Napa Gold. Put a Fram next to a HD filter or a Wix and you will see the difference.
Old 05-31-2008, 04:47 PM
SK8ROD's Avatar
SK8ROD
SK8ROD is offline
+1
Old 05-31-2008, 07:54 PM
twiceretired's Avatar
twiceretired
twiceretired is offline
I won't use Fram, but do use a quality filter. Just wanted to throw something out for thoughts. Filterable contaminants come from three sources: ingested through the intake system, deposited during the oil change process, and wear. If (big if here) we were using adequate air filtration, and clean change habits, a clean burning engine AND used a quality oil that significantly reduced wear, would we have to be so concerned about the filter?
Things that make you go HMMMMMMMMMMMMM.
Old 06-02-2008, 06:09 AM
roadking1893's Avatar
roadking1893
roadking1893 is offline
Since I went with amsoil I elected to go with their filter as well. personal choice since I've used amsoil ever since I started working on engines.
Old 06-02-2008, 06:22 AM
jkelley's Avatar
jkelley
jkelley is offline
I use purolator pure one's
Just paint "em" black
Old 06-02-2008, 10:47 AM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
ORIGINAL: twiceretired
Filter quality & designis very important on a TC or Evo engine. You need to pay close attention to how much oil pressure restriction and bypass pressure rating you get from any filter you use. Plus HD says they want 5 micron filtration with theTC engine so why go against that to save a few dollars? Likewise the EVO motors need a less restrictive filter to ensure proper oil flow to the engine top end.So for the few dollars you might save why take the chance you might create a very expensive and unwanted problem? JMHO.
Old 06-02-2008, 10:57 AM
twiceretired
I won't use Fram, but do use a quality filter: was my first statement. I use Wix, but might change if something better comes along. I don't cut corners on oil or filters, never will. For me, I'm at a time in my life where I want what I have to last. Don't do that by saving 50 cents on filters. I just threw that out for thoughts.
Old 12-23-2008, 07:59 PM
rocketmangb's Avatar
rocketmangb
rocketmangb is offline
Old 12-24-2008, 07:36 AM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
I just use the HD filter for my bike.I order them from Zanottis ,4-6 at a time.$11.5 ea. plus shipping.
My local dealer gets $14.95 ea plus tax.
I would not try to save a couple bucks by buying a cheaper filter.
Quick Reply: oil filters
