Oil Archive (no new posts) An archive of oil related questions and comments.
View Poll Results: A poll
Harley filter
55.42%
K&N Filter
22.71%
Amsoil filter
7.44%
Wix filter
5.14%
Fram filter
3.87%
Napa filter
1.10%
Revtech filter
0.66%
Purolator filter
1.54%
Hastings filter
0.08%
Mobil filter
2.03%
Voters: 3641. You may not vote on this poll
What Brand Oil Filter Do You Use
Old 07-03-2015, 07:07 PM
golfblues's Avatar
golfblues
golfblues is online now
Received 1,540 Likes on 932 Posts
Default What Brand Oil Filter Do You Use
Originally Posted by sn95bullitt
I was using the k&n filters from O'Reillys ($9) but I could never seem to get them of with out a problem. The part where you put the socket on the K&N one will snap of when you try to remove it. Then I have to poke a hole in it and spin it of with a screwdriver.
Lately I have just been using the black Harley filters. Only $6 bucks at the local dealership.
I've changed dozens of k&n and never snapped the nut. Sounds to me like you're over tightening it when you put it on.
WiSeNhEiMeR (07-06-2018)
  #472
Old 07-03-2015, 07:09 PM
sn95bullitt's Avatar
sn95bullitt
sn95bullitt is offline
Hand tight and one turn with the ratchet.
  #473
Old 07-03-2015, 07:26 PM
golfblues's Avatar
golfblues
That will do it. Hand tighten and a then 1/4 turn only with a ratchet. Don't forget to oil the seal first
  #474
Old 07-03-2015, 07:40 PM
sn95bullitt
1/4 turn is nothing. I have no problem with getting the Harley filters off.
  #475
Old 07-03-2015, 07:42 PM
Stiggy's Avatar
Stiggy
Stiggy is offline
Received 5,818 Likes on 3,172 Posts
Who taught you that? That's way too tight. You hand tighten to seat the rings and then hand tighten further no more than1/2 to 3/4 turn. No wrench used on installations.
  #476
Old 07-03-2015, 08:04 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 9,425 Likes on 5,020 Posts
Delete......
  #477
Old 07-03-2015, 08:06 PM
golfblues's Avatar
golfblues
Most filters need 1/2-3/4 turn once the gasket makes contact. If you hand tighten then 1/4 is plenty. These instructions are printed on most filters instructions.
If you are hand tightening than adding a full turn with a wrench you are over tightening the filter.
  #478
Old 07-04-2015, 12:05 AM
Not E'nuff Harley's Avatar
Not E'nuff Harley
Not E'nuff Harley is offline
I use the HD filter for two reasons. No one sells anything else locally, and I won't pay $20 for a chrome K&N anyway.
  #479
Old 07-04-2015, 11:21 AM
Quadancer's Avatar
Quadancer
Quadancer is offline
Heck, I think I paid only about $16 for the Amsoil EOM filter. Now running a ss screen cleanable tho, so no more buying them.
I use a piece of 1" pipe (closet rod) with 2 slits in one end and a long bolt thru the other, a foot of ratchet strap tucked into the slits. Sling strap umder the filter and turn the bolt in the desired direction: the best filter tool you can make.
  #480
Old 07-07-2015, 11:00 PM
retired by accident's Avatar
retired by accident
retired by accident is offline
Default oil filter
Originally Posted by OneBlackFly
Interesting that H-D are the overwhelming choice. Why? Can't be cost. What else, availability?
I think a lot of guys don't change their own oil, I know most of those I used to ride with Only two of us did. I switch to KN because I like the nut on the top which makes it easy to remove and I don't do chrome any more, who the hell sees them anyways!!!
Quick Reply: What Brand Oil Filter Do You Use
