decided to switch to syn, now what?
i decided to switch my fluids over to sythetic... i'm going with either the amsoil (if i can get it locally) or the mobil1... now i was wondering if i have to do the "total oil change" or if i can just do a standard oil change? also is there anything special i need to know about changing the fluids in the gearcase & primary?
RE: decided to switch to syn, now what?
If you're worried about the little bit of dino remaining in the engine mixing with the synthetic, don't- they're 100% compatible. (This can be verified at any oil manufacturer's website.)
As for the idea of doing a "total drain & purge" of the old oil, I wouldn't worry about that either. Some folks do it, and that (along with adequate maintenance) will probably get them 150k miles out of their engine.
Others just do a "regular" oil change, and that (along with adequate maintenance) will probably get them 150k miles out of their engine as well.
Just depends on how complicated you want to make it...
ShadowforNow
11-17-2018 02:16 PM
paulh1961
Oil Archive (no new posts)
10-09-2009 07:25 AM
