Oil Archive (no new posts) An archive of oil related questions and comments.
Rotellla T6 in M8 (crankcase), Bosch filters
Old 03-25-2024 | 07:57 PM
bson's Avatar
bson
Default Rotellla T6 in M8 (crankcase), Bosch filters
Any reason not to use Rotella T6 in a Milwaukee-8? If not, under $25 per gallon at Walmart makes it attractive. Claims "extreme heat protection", not sure what if anything that means (perhaps high smoke point and shear resistance), but I assume it can't hurt in an air & oil-cooled engine. Hey, there's a bike on the label!
Anyone find a reason to dislike Bosch filters? I've used those forever with other bikes.
Old 03-25-2024 | 08:18 PM
Rusty Springs's Avatar
Rusty Springs
Deleted. I didn't realize T6 was available in 15w-40.
Old 03-25-2024 | 08:21 PM
mjwebb's Avatar
mjwebb
yes, because it's a 15W40 and the required manufacturer's spec is 20W50 .. it really is that simple
The following 3 users liked this post by mjwebb:
downzero (03-28-2024), KK0G (03-26-2024), Ohio HD (03-25-2024)
Old 03-25-2024 | 08:25 PM
Ohio HD's Avatar
Ohio HD
I run 20w-50 or 20w-60. Brand of oil won't cause engine damage, but too thin of a weight sure can.
I use WIX oil filters or S&S as they're made by WIX. I order a case of the S&S at a time from my Indy shop.
NorthWestern (03-25-2024)
Old 03-25-2024 | 08:50 PM
bson's Avatar
bson
Oh, you're right - for some reason I thought it was available in 20w50. Well, that would make it an eminently bad idea!
Old 03-25-2024 | 09:17 PM
BrandonSmith's Avatar
BrandonSmith
Originally Posted by mjwebb;[url=tel:21621110
21621110]yes, because it's a 15W40 and the required manufacturer's spec is 20W50 .. it really is that simple
Agreed. Keep in mind startup and operating temperatures though as viscosity changes with temp. AND… SAE viscosity can vary by 20% and still be acceptable!
Top things I learned in my training:
  1. Viscosity is the single most important aspect of selecting any lubricant.
  2. The oil film (the barrier that oil creates between two sliding surfaces) is only 1 to 3 MICRONS (that’s millionths of a meter, or about 1/40th the size of a human hair).
    • Never reduce viscosity below OEM recommendation. Viscosity could be increased to 3x OEM recommendation, but there are other restrictions and considerations.
bson (03-25-2024)
Old 03-25-2024 | 09:33 PM
BrandonSmith
I wouldn’t use the Bosch 3330 personally.
Filter is made from cellulose with fiberglass added. Does not flow as well or filter as well as a true synthetic/fiberglass.
Also, it’s only a 20 micron filter. It’s not going to filter anything less than that. Generic marketing for Bosch Premium filters is 99% effective at removing 20 microns.
Knowing that the oil film protecting metal from wear is only 1-3 microns, I don’t want 5 micron particles flowing through my oil, let alone 20 micron.
The following 2 users liked this post by BrandonSmith:
bson (03-25-2024), mjwebb (03-25-2024)
Old 03-25-2024 | 10:08 PM
bson's Avatar
bson
Excellent. Just the info I was looking for - thanks!
Old 03-26-2024 | 09:45 AM
xcbullet's Avatar
xcbullet
The filter is fine but not the oil.
bikerjenna
09-13-2011 11:16 PM
lizdc
01-15-2010 10:39 AM
monkish
09-26-2007 11:19 AM
brohrs
08-04-2006 05:26 PM
2005UltraNC
Exhaust System Topics
01-30-2006 05:38 AM
Quick Reply: Rotellla T6 in M8 (crankcase), Bosch filters
