Is Mobil1 compatable with HD360
I'ms sure this has been asked before but I want to convert from HD 360 conventional oil to Mobil1 in the engine. Do I need to worry about flushing out all the old oil or is Mobil 1 compatable with the conventional Harley oil. I know there is at least 1/2 quart on a normal change which is still in the engine.
Thanks
Thanks
RE: Is Mobil1 compatable with HD360
No problem Just drain and refill. I like to drain when it is hot and let it sit over night with the plug out. Not necessary but you do get a little more out that way. Mobil is compatible with petroleum so the little that is left won't hurt a thing.
No need to flush.......just drain the old out and in with the new. I wouldn't deliberately mix the two though.
ORIGINAL: bear95252
OMG!!!!! No Amsoil plug and a straight answer?????
