Oil Archive (no new posts) An archive of oil related questions and comments.
VR1 Oil Change
Old 11-08-2022, 06:39 PM
loco2wlr's Avatar
loco2wlr
loco2wlr is offline
Default VR1 Oil Change
What is your oil change interval with VR1?
Old 11-08-2022, 09:02 PM
Wapiti Hunter's Avatar
Wapiti Hunter
Wapiti Hunter is offline
Received 1,422 Likes on 237 Posts
3k miles
Vec (11-09-2022)
Old 11-08-2022, 09:07 PM
mjwebb's Avatar
mjwebb
mjwebb is online now
Received 9,376 Likes on 4,783 Posts
user 'opinions' will vary greatly...if you truly want to know what's best for your engine's lubrication requirements simply follow your motorcycle owners manual instructions.. which are provided by the professional subject matter experts who designed, developed, tested, produced and provide warranty on their engines
TriGeezer (11-08-2022)
Old 11-08-2022, 09:18 PM
chopper_man's Avatar
chopper_man
chopper_man is offline
Received 1,665 Likes on 990 Posts
3k for traditional, 5k for synthetic.
Iron lHorse (11-09-2022)
Old 11-09-2022, 06:06 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 9,446 Likes on 5,032 Posts
5K, just like the owner's manual says.
The oil is still fine at 5k miles, the only benefit of changing it sooner is it makes more money for the companies that make oil and filters, and all the middle men.
The following 2 users liked this post by Dan89FLSTC:
Mountainkowboy (11-19-2022), Yankee Dog (11-27-2022)
Old 11-18-2022, 12:06 AM
60Gunner's Avatar
60Gunner
60Gunner is offline
Received 1,212 Likes on 904 Posts
and you know it's fine because...?
I run vr1 and change it every 2500 to 3000 miles. How you ride makes a big difference and I wouldn't run 5000 just because you're running synthetic. I'd run vr1 5000 before a lot of the synthetic MC oil Some break down sooner than a good conventional. Especially motorcycle oil aka oil designed to work in wet clutches.
As for cost of changing sooner than later? Who cares. Oil is cheap. I pay 3.99/qt for vr1.
if you're dumb enough to pay $15 /qt for an inferior designer MC oil...
buell95 (11-18-2022)
Old 11-18-2022, 06:12 AM
mjwebb's Avatar
mjwebb
it's fine because manufacturers building engines say it is..this applies to HD, Toyota, John Deere, Evinrude, Ford, Briggs & Stratton, Toro, etc.....they know more than you about their engines..it really is that simple
The following 2 users liked this post by mjwebb:
eighteight (11-21-2022), NorthWestern (11-18-2022)
Old 11-19-2022, 08:48 PM
Dan89FLSTC's Avatar
Dan89FLSTC
I sent a sample of the oil to a lab at 5K and the results said the oil was fine, that is how I know.
I don`t care how often you change your oil, or your reasons why.
I`m confident in the way I maintain my machines and the advice I give to people, based on 50 years of experience as a professional mechanic (42 years as a licensed airframe and powerplant mechanic).
Old 11-19-2022, 10:06 PM
M Oclaf's Avatar
M Oclaf
M Oclaf is offline
Received 5,803 Likes on 2,678 Posts
Default Mines bigger
Than both of youz…
Old 11-21-2022, 03:29 AM
robarosa's Avatar
robarosa
robarosa is offline
VR1 has high levels of zinc but lower levels of detergent. VR1 should be changed more often.
NorthWestern (11-21-2022)
Quick Reply: VR1 Oil Change
