Oil Archive (no new posts) An archive of oil related questions and comments.
Used Oil Analyses (UOA)
Old 03-03-2009, 08:01 AM
big cahuna's Avatar
big cahuna
big cahuna is online now
I just looked at Harley's syn3 voa, and saw that Pococj's last uoa had higher numbers of phos,cal,and zinc. moly was real close. If a Harley can last 100k on syn3 oil, his bike should last forever with his mix.,,
Old 09-16-2009, 08:25 PM
rodney123456's Avatar
rodney123456
rodney123456 is offline
where do you all get the oil analyzed?
Old 09-16-2009, 09:07 PM
nocarb's Avatar
nocarb
nocarb is offline
Polaris Labs.
Old 09-18-2009, 06:17 AM
pococj's Avatar
pococj
pococj is offline
Received 1,296 Likes on 483 Posts
Blackstone Labs
Old 09-18-2009, 06:19 AM
Nightking's Avatar
Nightking
Nightking is offline
The only way to get a good report , is to start with a new bike. Getting oil samples is like checking fuel mileage. It's gonna be the same regardless of what you know.
Old 09-19-2009, 02:14 AM
rocketmangb's Avatar
rocketmangb
rocketmangb is offline
Default Uoa
This is true to a point
The first sample says nothing unless you get an abnormal
every test after that should tell you something.
Old 10-01-2009, 08:40 PM
nocarb's Avatar
nocarb
nocarb is offline
Default 9 UOA's HD 360 and Amsoil MCV 20W50
These are from my 08. Samples 1 and 8 are HD 360. All the others are Amsoil MCV 20W50.
Old 11-05-2009, 08:29 PM
vindex1963's Avatar
vindex1963
vindex1963 is offline
This oil was ran for just over 5,000 miles in AZ heat. Some days it reached 115* and we did a 250+ mile 2-up ride. The oil temp gauge would read 270+ for most of this oil's life. I expected it to be totally broken down but it looks pretty good.
P.S. It's auto Mobil 1 15-50. Who really needs that $$V-Twin$$ on the bottle.
The TBN is excellent.
Old 11-17-2009, 12:00 PM
big cahuna's Avatar
big cahuna
Has Blackstone ever returned a report where they recommend changing the brand, or type of oil due to extreme wear or for any other reason? Every report I've read says the oil is fine. Seems they only recommend when to change it, so by that in their eyes you can run any oil out there, and it will do the job. They test mixture's of oil that guys make in their garage and their reports say it ok to use, and how long before it should be changed. I think they would be more credible if every so often they said don't use XXX oil, its not working for your motor. Otherwise any oil out there is the right one for your application.,,
Old 11-18-2009, 12:58 PM
vindex1963's Avatar
vindex1963
You're right in a way I think. I think it shows a name brand quality oil will do fine weather it's $1.99 per qt on sale car oil or $12.99 per qt V-Twin oil. In the end they are both good. I choose car oil because the V-Twin on the bottle isn't worth the extra $$$ to me. I get mine 5 qts @ $22.00 for Mobil 1 15-50.
Quick Reply: Used Oil Analyses (UOA)
