Another oil pressure question!!!
I have an 06 Ultra Classic. Stock twin cam 88 engine. Just had my 5000 mile service done and I never noticed this before. I'm going to call my dealer tomorrow about it but I wanted some input here until i call.
When the engine gets to operating temp the oil pressure drops to almost 0 when stopped and engine is idling. When running at highway speed ( 60-65 ) the oil pressure is almost 32 psi. any other twin cam 88's do this?
RE: Another oil pressure question!!!
ORIGINAL: MACK
ALL OF THEM DO IT. PERFECTLY NORMAL. YOU WILL GET BETTER PRESSURE WITH AMSOIL SYNTHETIC OIL. I USE IT AND HAVE NOTICED THE DIFFERENCE.
When I had an oil pressure problem due to a loose return hose clamp, the dealer explained that the HD oiling system is based onoil volume , not pressure. As the oil heats and thins, pressure falls noticibly at idle but (he claims) volume is sufficient to lubricate.
EZ
EZ
