Primary capacity
Primary capacity
I was thinking the primary held 1 quart. The owners manual for a 1997 heritage softail classic says primary 38-44oz.
Is that maybe only if you have the whole primary taken off the bike?
Thanks.
Thanks.
Typically they give it two amounts...a wet change and a dry change...where the inner primary was removed. I just trust my eye and fill to just barely the bottom of the clutch basket, it's usually right around a quart.
bulldog1776 (04-16-2022)
My 2018 Heritage service manual says to set the level at the bottom of the clutch basket, also. Don't do this with the bike on the jiffy stand. Bike must be upright to set the level correctly.
The following 2 users liked this post by Steve Sportster:
bulldog1776 (04-16-2022),
RANGER73 (04-09-2022)
from the center of the clutch adjusting nut to the top of the fluid.
On newer models, to the bottom edge of the diaphragm spring.
Most do not need 38 oz to do that. Two quarts will have a little left over when you do primary and transmission. Use non detergent gear oil like Harley's Formula plus.
It works well in all temperature ranges. No filters, so that's why you need non detergent.
bulldog1776 (04-23-2022)
The following 2 users liked this post by bklynbob:
bulldog1776 (04-23-2022),
guido4198 (04-23-2022)
