Oil Archive (no new posts) An archive of oil related questions and comments.
Mobil1
Old 05-12-2021 | 06:26 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Default Mobil1
Anyone use Mobil1 full synthetic that is API SN, SM, SL? It's a 15w50 full synthetic motor oil.. pros/cons.. thanks
Old 05-12-2021 | 06:57 PM
86glider's Avatar
86glider
Hey Bob, been using it in my 86 since 95. When I freshened up the top end after 33K, had absolutely no wear.I will keep using it.And those myths about leaks ? I’ve had no issues.That’s my .02
98hotrodfatboy (05-13-2021)
Old 05-12-2021 | 07:25 PM
98hotrodfatboy
Thanks Don, I've been using it in a 89" stroker Evo for over a year now without issue as well. I should have been clearer about the application.. I'm wanting to use it on a TC 103" motor..
Old 05-12-2021 | 08:05 PM
86glider's Avatar
86glider
I would think you’d have the same positive results.
Old 05-12-2021 | 09:56 PM
98hotrodfatboy
So far I did.. How you been man.. ?
Old 05-13-2021 | 07:06 AM
guido4198's Avatar
guido4198
I ran Mobil Syn 15/50 in my 80 cu in. EVO for a couple years during a time when I was riding the bike to work everyday and putting approx. 450-500 mi per week on her. I wanted to take advantage of a longer oil change interval. It tended to be difficult to find as a good price and I did notice the mythical "Seeping" happening. Eventually went back to Castrol 25/50 and change oil/filter every 2500-3000 mi. Easy to find where I am, less expensive...(even given the shorter interval), and no mythical seeping.
Old 05-13-2021 | 08:38 AM
hd4evr2008's Avatar
hd4evr2008
Been using Mobil 1 15w 50 in my Twin Cam 2007 Street Glide for years! It has a great additive package, better than most so-called "motorcycle oils. I buy the 5 qt. jug at Walmart for $23.88, then Mobil has a $15 rebate, which means I get 5 qts. of oil for less than $2 a qt. I think you'll be very pleased with using it.
The following 3 users liked this post by hd4evr2008:
98hotrodfatboy (05-13-2021), Iron lHorse (01-14-2023), Stiggy (05-14-2021)
Old 05-13-2021 | 04:00 PM
98hotrodfatboy
how did you find the rebate?
Old 05-13-2021 | 05:00 PM
hd4evr2008's Avatar
hd4evr2008
https://www.mobil.com/en/lubricants/...-1-2021-rebate
Old 05-13-2021 | 05:47 PM
60Gunner's Avatar
60Gunner
Shears easily. To a 30wt at that. In a sporty. Lot more where that came from too.
Maybe if you baby it. Stock? Performance cams? Cams and lifters are where wear happens first.
https://bobistheoilguy.com/forums/th...ortster.91414/
