Oil Problem
Oil Problem
Forgive me if this is in the wrong section. I'm new to this forum.
I am having an oil leak problem and I was wondering if anyone could help me. After I runthe motor for a long time it leaks a lot of oil from the rocker arm or the rear pushrod at the top. I was wondering if it sounds like a simple push rod seal replacement might fix this or not...? I'm not sure if it is leaking from the pushrod or the rocker arm. Any suggestions?
Also,My bike is not charging my battery for some reason. I think that the oil may have leaked on the brain box and ruined something. Does this sound possible? Or do you think it may just be the alternator?
Thank you in advance for your help...
marine_hm@hotmail.com
09-15-2012 12:41 PM
