Syn3 in the transmission
RE: Syn3 in the transmission
Your right Tail, I checked AutoZone in my area (was lucky and bought the last 8qts) but the guy told me AutoZones are discontinuing the Mobil 1 V twin ! Nobody else here has it !! And maybe Albersons carries it, but here in Central IL we aint never heard of a "Albertsons"...?
Harley is offering a new oil called Formula+ for transmissions and primary. Not sure if it's any better than Syn3, but if you want to stay with a HD product, you might look into using it.
hey guys, could we make a sticky here? i will forget by morning and i believe you.
now was that mobile 1 v-twin ibn the engine, redline in the trans and syn3 in the primary?
im confused already, but want the best in my bike!
im confused already
im confused already
That was that mobile 1 v-twin in the engine, redline in the trans and HD primary oil in the primary!
Use your bookmark(favorites) to save it, it works better than memory
I was at my Harley dealer today and they had a new SE Fatboy in the showroom with the Syn3 sticker on the primary case that indicated it was in all 3 cavaties. So if its good enough for a high performance $30,000 bike...it must be ok for mine. I used it in my Sportster all 3 cavaties no problems at all....and the engine was definitely smoother. KB
ORIGINAL: MikeP
Is redline shckproff avaialbe at local auto stores?
You may find it at a speed shop or you can order it here shipped to your door... http://www.myoilshop.com/
ORIGINAL: KBFXDLI
Not so, there are problems coming up with the use of the Syn 3 in thre transmissions. The better lube such as redline or mobil 1 75/90 will also make it shift better so don't believe everything the dealer says or even the MOCO for that matter.
By the time the problem pops up using the Syn 3 in the trans, it will probably be out of warrantee any way. Syn 3 is a motor oil , NOT a gear oil and mazola will work in there if you want to try it.
