leaking oil everywhere on start up...help!!!
Ok i have a 92 softail and after the bike sitting for 6 months i went out today to start it and the thing started gushing oil out everywhere. It seems to be comming out of the right side but not 100% sure. Any help would be great! thanx again
Oil probably drained down to the bottom of the motor. Start the bike it builds pressure in the motor before all the oil can get pumped back into the bag. Oil get pushed out the breathers.
'92's were crankcase breathers. after they sit for a while oil will seep into the crankcase past a checkball in the oil pump. when you start it the flywheel spins all that oil around and it comes out the breather hose.next time find the hose,put a pan under the bike to catch the oil then pour it back in the oil tank when it stops comming out.. let it warm up, check the level then go for a ride.my buddys bike does the same thing. If he rides it alot it doesnt do it as much.,,
I am really no mechanic...i was affraid i was going to blow the motor....What do you suggest it do? can i let it run? I mean the thing was puking oil all over my driveway....will it stop leaking by itself??
ORIGINAL: harry64chevy
ORIGINAL: big cahuna
well if your on the left side of your bike, look over the large shiny primary cover an there should be two short black hoses. one is on the top side of the trans and the other should be on the rear , behind the motor. that one is your breather hose from the crankcase. thats where the oil shoots out. under that hose is where you put the pan. as far as oil go to the dealer and get oil there as you may want to change it at some time and at least you'll get the right type of oil .20/50 wt will do the job.you might get a half to a qt of oil, but I doub't youll get more then that.it will stop after probably less then a minute. just keep the pan handy.if it does not stop at all you might need to get it to a shop to take a look at it.best I can tell you from here.,,,
I'm experiencing the same problem with my 1980 Electraglide FLH. I replaced the oil pump last year, and yesterday when I started it for the first time this year it dumped about 1/2 to 3/4 qt of oil. I figured it might so luckily I had a pan under it. Is there any way to stop this from happening? Or is it just an expected thing after the bike sits for a while without being started?
jammer1
Oil Archive (no new posts)
02-14-2006 09:08 PM
