My test of Mobil 1 vs Amsoil
Just thought you might like to hear a real road test under somewhat warm conditions here in Az.
Last week in 115 deg F weather at cruise speeds with Mobil 1 V twin oil, Mobil 1 in the tranny and syn III in the clutch (didn't swap the clutch oil), I would regularly see 230-255F on the engine oil temp at cruise of 75-80mph after about 1 hour of driving. Usually stayed at 230F. I do have an HD oil cooler, it kicks in at about 195F (oil temps hold at 195 for about 10 minutes, then it slowly increases as whole motor heat soaks.)
I thought I would try Amsoil, so after a 500 mile breakin of a new cam, I had the guys swap all the holes to Amsoil. I just finished that ride a few minutes ago, and after cooling off in the pool, heres the numbers and impressions.
Still 115 degrees ambient, still cruising at 75-80 for about an hour, results in exactly the same temps in the motor; 230-255F. I could not hear or feel any difference in motor or tranny while driving or shifting.
Overall, I could see no difference between Mobil 1 and Amsoil, which is good.
I do however note a huge difference from when I used Dyno/Syn III and now the synthetic mobil/amsoil. It's cooler, it's quiter, it shifts smoothly. Just my opinion, I may be wrong.
Going back to pool...
RE: My test of Mobil 1 vs Amsoil
Agreed. I tired Amsoil casue my indie had it, I needed a change so walla. But next time, unless the autozone down the street carrys it, I'll be back to Mobil 1 v twin. Simple, cheaper.
So .. which Mobil 1 in the primary? 20W50, 10W40, or something else? Thanks.
(on another note - tried SYN3 in the engine and it now runs hotter and noisier than w/ Red Line 20W50 - back to Red Line soon)
UPDATE, tranny is obviously harder to shift. With Mobil 1, it was smooth in all gears, could even get a green like neutral from 2nd, not even close with the AMSOIL, it's shifting notchy and taking a few taps/wacks to get into gear. Going back to Mobil 1 gear oil this week.
ORIGINAL: beemer737
[IMG]local://upfiles/33788/648443EB88444FA9B72DDA6778EA31BB.jpg[/IMG]
Regarding the Mobil 1 gear oil, is there any advantage/benefit of the 75W140 over the 75W90, or vice versa? Thanks.
(btw - I know there is a cost difference between these two gear oils, but I'm asking about performance)
ORIGINAL: OneBlackFly
