Recomendations for OIL for U.K. market
Hi All,i was wondering what the british riders recommended brands of oil are for the U.K. market.
I've read lots in this section but it seems mostly confined to the States.
I'm running a 94 Sportster and would like to know what everyone this side of the pond recommends.
Any advice appreciated
RE: Recomendations for OIL for U.K. market
I would reccomend RedLine products. I get mine mail order.
From one of these depending on who is cheapest at the time.
http://www.mtmotorsport.co.uk
http://rallynuts.com
Sometimes it can be found on ebay, or if your lucky check your local motorfactor as some will order it in for you, or may even stock it.
Expect to pay between £44 and £50 for a gallon for the engine oil.
If you contact the RedLine tech dept., they will let you know which of their oils will fit your needs. Sorry I dont know much about sporties, and you may need different oils to me.
Hope that helps
WB
Colchester.
Hope that helps
WB
Colchester.
Thanks WB for that info,i've found an importer of Amosil products in the U.K. as well
Here:-
http://www.performanceoilsltd.co.uk/..._davidson.html
Here:-
