1st oild change help needed
"04 Harley Sporster 1200 in Texas just got bike and pushed past 1000 miles, so book says first oil change is due. what type of oil and filter recommended. daily driver, but only 3 miles to work
RE: 1st oild change help needed
If in doubt swing by the dealer and get HD360 dino or Syn3 synthetic oil in 20W-50 and a H-D filter.
Can't go wrong with what H-D recommends...
If you watch this forum you will see that not many folks are happy with Harley Syn3, I know I wasn't. Most use a high quality Synthetic like AMSOIL MCV 20/50 or Mobil 1 V Twin 20/50 Others like Redline. They are all good choices. Even Syn3 is ok, Made my motor sound real noisey.
If you would like AMSOIL, I can help you with that. Email me.
skylane19641@mac.com
Bear
03 Ultra Classic
Agree on the filter OR Pure One filter OR K&N OR Amsoil, etc.
Buy syn III ONLY if you want to pay the most for the least impressive syn.Of course, Citgo andEl Presidente de Venezuela will appreciate your business!
Mobil one 15/50 would be cheapest and easiest better choice or, the high priced speads Amsoil OR Redline oils.
The HD 360 Dino might be a good choice if you plan to change it very often because of your low milage daily trips.
EZ (lots of threads here to educate yourself but , almost all agree that Syn III is NOT a good buy for the money.
EZ
EZ
ORIGINAL: coach04sport1200
I know you have had the bike for only a month or so and have added 500+ miles in that time but do yourself and the bike a favor and get up early and ride the long way to work and back, say 15 + miles each way. The oil and filter issues were well covered above.
Enjoy the ride,
FBL
Enjoy the ride,
FBL
I agree with most on here...Used what you like. I used to run SYN 3 in all 3 holes but switch over and was really surpprised at the results. I use Mobil V Twin (got it at Wal-Mart- $8.23 qt), Mobil 1 75W/90 Syn gear oi for the tranny and H-D Fomula + for the primary...if you read this forum you will see and learn that everybody has diffrent combs and oils they swear by so with that said..read a little and used what you feel comfable with. If you do like it you can change it out next time you change the fuilds
Good luck and you really can't go wrong using any top oil and filter
