Engine stalled oil light goes on
Good morning I'm hoping I can get an answer. I was run off the road last week guy took a turn real wide had no choice but to go on grass very wet muddy bottomed out bike is fine cause magically cleaned it out still somewhat in certain areas was running OK a week later started it ran it for about 45 blocks started hesitating stalled oil light on Wouldn't start high to walk it home next day started cold No problems no light definitely something going on not sure what it could-be I'll admit this is my 1st Harley never worked on and before but I am mechanically capable don't really wanna pay a $100 per hour at my local Harley to troubleshoot something that May be simple help please
I don't know what year or model bike he has. Filters and sending units are in different places.
2004 1200 custom I'm looking at it and a few wires and harness seem a bit loose but nothing seems off or broken
Swapping parts will cost you a lot more in the long run.
First Check for codes if you are getting the light there will be one. It requires no special equipment to do so.
It could be a damaged Crank sensor also the code will likely give you a pretty good idea what is causing it.
Also year and model would help a lot.
