Oil Archive (no new posts) An archive of oil related questions and comments.
Oil filter housing
Old 11-16-2016 | 10:29 AM
65049's Avatar
65049
Default Oil filter housing
Has anyone heard of doing this or have done this, removing the oil filter mount from the motor and plumbing it for a remote filter mount?? Looking at an 2013 103" to buy and this has been done to it.
Old 11-16-2016 | 12:00 PM
TinCupChalice's Avatar
TinCupChalice
Running the DK Custom oil filter relocation, it's a very worthwhile upgrade. Monitoring temperatures with my Power Vision before and after the install I'm seeing a 15° - 17° engine temperature reduction with the oil filter relocated; the oil filter is a FLO PSC4C permanent oil filter.
It's a simple process to remove and clean the PCS4C oil filter, absolutely mess free oil changes now, no oil drooling when you pull the hot filter
I did an install thread on the relocation HERE
W.Glide (11-30-2016)
Old 11-16-2016 | 01:31 PM
65049's Avatar
65049
This kit looks like you can remove and go back . The guy that has the engine said his you can't go back unless you change that part of the engine with a new block
Old 11-30-2016 | 08:12 PM
W.Glide's Avatar
W.Glide
Thanks for posting that Tin! I've been looking at one of those from DK for my WideGlide as well. The stock location just flat stinks, and I don't think there is a way to change it without making a mess. The BIG plus with the remote and the filter is the reduction of oil temp.
Old 12-01-2016 | 06:40 AM
grbrown's Avatar
grbrown
What brand of filter housing has that guy used? Without a bit more info we can't help much.
My Evo came new with a remote filter housing, it was only in the mid-90s that H-D went to direct mounted ones.
Old 12-01-2016 | 07:45 AM
buell95's Avatar
buell95
v
Are these parts from two different kits? The reason i ask is your front down tube
Filter bracket is the same exact one i run except for different hose fittings.
It is made out of Aluminum from 3GUYZ.COM. Not sure why half your kit is cast.
TinCupChalice (12-01-2016)
Old 12-01-2016 | 09:44 AM
TinCupChalice
Thank you for that information, buell95! Wish I'd known that sooner
https://www.hdforums.com/forum/dyna-...l#post15721986
Old 12-01-2016 | 04:46 PM
lt1-xjs's Avatar
lt1-xjs
I used the Dorale 15703 spin on adapter and the 3 Guy's filter head.Oil filter housing-img_20161201_151634_673.jpg
smokingjoe
Milwaukee Eight (M8)
37
07-24-2017 11:44 AM
30glock
2014-2023 Touring Models
18
06-10-2016 05:54 PM
RoadKingHellas
02-10-2013 01:24 PM
blueangel73
09-02-2010 09:27 PM
tennessee streetglide
06-06-2009 10:01 AM
Quick Reply: Oil filter housing
