Oil Archive (no new posts) An archive of oil related questions and comments.
Mobil 1 15-50 vs Mobil 1 V-Twin 20-50
Old 09-23-2017, 08:22 PM
rocket23's Avatar
rocket23
rocket23 is offline
Received 3,615 Likes on 2,870 Posts
everyone stay calm.......slide the keyboard away......we do NOT need another oil thread debate!!!
  #32
Old 09-26-2017, 03:49 PM
60Gunner's Avatar
60Gunner
60Gunner is offline
Received 1,212 Likes on 904 Posts
Originally Posted by HKMark23
If that were true I'd go cheap too but it isn't. Best you just do a bit o Googling rather than me launching into a full Monte diatribe about the differences. There are many.
then keep buying it by all means. I read a lot of $h!+ on the internet...
  #33
Old 09-26-2017, 04:50 PM
HKMark23's Avatar
HKMark23
HKMark23 is offline
Received 1,940 Likes on 1,116 Posts
,,,,,The only thing synthetic has over conventional is length of service intervals. ,,,,,,
Don't care what you buy either Speed, just calling BS on your BS is all.
  #34
Old 09-27-2017, 01:27 AM
Ddieselsmoke's Avatar
Ddieselsmoke
Ddieselsmoke is offline
Get on bobistheoilguy.com and you can read all about oil till you are sick of it.
  #35
Old 10-02-2017, 12:10 PM
Ddieselsmoke
I'm thinking about 15/50 in mine when my free services run out. I ride up until the salt trucks come out. I get off work at 2:30 in the morning so it's a little chilly. Turning over it's grunting a little when it gets in the 40's. I have 20W50 360 in it now, but it's changed every 2,500 miles.
17' FLSTC. 5,200 miles.
  #36
Old 10-03-2017, 04:47 AM
HKMark23's Avatar
HKMark23
HKMark23 is offline
Thought of trying a group IV or V synthetic ? One of the characteristics of it is that it thickens less than a Dino oil when it cools. It contains NO wax. Otherwise, all oils are designed to be roughly the same viscosity at operating temps, (212 deg.), 10-15 cSt.
  #37
Old 10-06-2017, 11:05 AM
HDSlimJim's Avatar
HDSlimJim
HDSlimJim is offline
Check your manual, but for mine, if the ambient air temp is below 50, I can step down to a w40 oil. Now that it's getting colder, I'm looking at 0w40 Mobile1 in the engine to finish out the year, and start next year, with some easy cold starts.
  #38
Old 10-06-2017, 12:28 PM
rocket23's Avatar
rocket23
rocket23 is offline
interesting point here; Isn't a full synthetic just as liquidity (for lack of a better term) at lower ambient temps as it is at say 80 degrees? So would the owners manual be conventional oil minded in their statement? And if that is the case a mere 40 degree difference wouldn't matter to me using a full synthetic oil with a 15w-50...weight
  #39
Old 10-06-2017, 02:09 PM
HKMark23's Avatar
HKMark23
HKMark23 is offline
At operating temp, none of it matters. Any 50 wt oil you use will be almost the same with respect to viscosity. Its during and shortly after you crank her up that the differences occur. Synthetics thicken less as temps drop and this characteristic continues beyond published 40 degree viscosity. Synthetic oil will remain thinner when cold hence be lubricating your engine better, sooner than waxy Dino oils on cold starts. Thats just one of the benefits. There are others.
  #40
Old 10-06-2017, 02:18 PM
Notgrownup's Avatar
Notgrownup
Notgrownup is online now
Received 7,123 Likes on 3,659 Posts
That's some fancy slick **** there buddy... Where d'you get it... WAL-MART... It's mighty Purdy...can I try it? No it will make you nads hot...damnit Jim, I'm just a country doctor.
Quick Reply: Mobil 1 15-50 vs Mobil 1 V-Twin 20-50
