Oil Archive (no new posts) An archive of oil related questions and comments.
Primary oil capacity...wet or dry?
Old 04-17-2016 | 12:22 PM
TriGeezer's Avatar
TriGeezer
Default Primary oil capacity...wet or dry?
Sorry, another **** question from me, while working on my clutch. So, I drained the primary, pulled the primary cover, and replaced the clutch Diaphram Spring. After adjusting the clutch, I'll button it all up and refill with Formula+.
Yikes! The manual says the capacity is: 38oz wet, 45 oz dry.
So, is my primary wet or dry? I assume this has to do with restrained fluid. But with the primary cover off for 2 days, it's hard to believe it has retained 7 oz.
How much should I fill it with in this situation?
Thanks!
Old 04-17-2016 | 12:24 PM
qtrracer's Avatar
qtrracer
wet is drained out the plug. dry is cover removed. either way start with a quart and fill to level specified, bottom of clutch with bike level.
Old 04-17-2016 | 01:05 PM
TriGeezer's Avatar
TriGeezer
Thanks!
Old 04-17-2016 | 07:01 PM
grbrown's Avatar
grbrown
Just fill to the correct level. Doesn't matter how much that is, just have around 45 oz available. The quantities you mention are a guide, not the amount you simply pour in without checking the level is correct!
Old 04-20-2016 | 10:25 AM
mdm's Avatar
mdm
"Wet" = a primary that has been drained
"Dry" = a clean, newly assembled primary. The clutch, chain, sprockets and all the interiors surfaces will hold more oil than you think.
Old 04-20-2016 | 05:22 PM
Dan89FLSTC's Avatar
Dan89FLSTC
This is the correct max level for any big twin clutch since mid 1985, (a little lower than this won`t hurt a thing).
Bike vertical.
tonycap
EVO
38
06-01-2013 07:39 PM
fergml
03-09-2013 03:29 PM
big TYME
05-10-2012 11:20 PM
RoadKingon
04-25-2007 11:42 AM
jube455
13
04-24-2006 10:00 AM
Quick Reply: Primary oil capacity...wet or dry?
