Gear Oil 85 /90 or 85 / 140
Getting ready to buy some gear oil for the transmission. I have narroed it down to two types. Bel Ray or Mobil 1 Able to buy it locally. I am leaning towards mobil 1. I can't find anywhere where it states bel ray being synthetic.
Question is 85 / 90 or 85 / 140
Thanks
Thanks
RE: Gear Oil 85 /90 or 85 / 140
Gear oil weights are rated with higher numbers than motor oils. The heavier gear oils are really equal to (appx) a 20/60 motor oil in weight.
Bottom line, the heavier may run quieter in hot climates and the lighter may be better in cold weather. Kind of like motor oil but definitely NOT as critical and either will probably exceed the protection of using a motor oil instead of a gear oil.
Rough equivalents of weight of motor vs. gear oils.......................
SAE Engine Oil SAE Gear Oil
10w thru mid range of 20w 75w
Mid 20w thru mid 30w 80w
Mid 30w thru low 40w 85w
Low 40w thru 50w 90w
60w up 140w
Lots of this info is available in the forum just above this one in the form of FYI info from fairly expert posters.
EZ
60w up 140w
EZ
Does not matter as long as you have gear lube in there. 85w90 or 85w140.....either one is ok.
ORIGINAL: 05 HD Deluxe
Thanks
Thanks
Thanks for all the reply'severyone
Just want to confirm that the mobil 1 gear oil we are talking about is the one typicaly used in cars right. It says nothing about motorcycle's on the bottle.
I have found both at the local auto parts store. Quite a difference in price. 10.00 for 85/90 or 20 for the 85 /140. Only takes 1 quart so I am willing to pay the extra for the 140 if that is the way I go.
Thanks again
Thanks again
