06 Ultra Classic oil change
Hello can someone tell me if the oil in the motor & transmission are the same ? I know there is 2 oil plugs under the bike. The dealer wants $390.00 for a 10,000 service. Help would be great
RE: 06 Ultra Classic oil change
You can use the same. I wouldn't though. I would use something like Amsoil SVG75/90 or Redline Shockproof heavy in the tranny and you'll be happier
Take a look through your owners manual under theoil change section, it will show and explain everything to you that you will need to know. The owners manual is pretty handy if you thumb through it, it will give you a lot of information about your bike. Better yet get a sevice manual there worth the $$$ spent to have.
Take Care,
Bill G
Take Care,
Bill G
In the big twins the motor oil and the trans oil are not the same. There are two drain plugs to service them individually. Use something like Mobil 1 V Twin 20/50 in the engine and Mobil 1 75/90 or 75/140 in the transmission and you'll be in good shape.
You can get a service manual for about $50 and do it yourself and save a lot of cash. It's really not that difficult. The plug that is in the corner of the oil pan facing foward is the engine oil and the other one facing downward is the transmission drain plug.
Here's a link to a printout of what needs to be done on the Ultra.
http://www.psndealer.com/dealersite/...%20Touring.pdf
ORIGINAL: glide
