2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
OK...where is it?
Old 10-25-2018, 06:54 PM
pcmc2's Avatar
pcmc2
pcmc2 is offline
Received 7,284 Likes on 1,059 Posts
Default OK...where is it?
My '14 FLHTK that I bought new had a battery tender pigtail installed and was routed along the rear fender. My '07 FLHTCU that I bought used had one also and was routed below the right side side cover. Now I have a '15 FLHTK that I bought used and I've looked everywhere (right side, left side and under the seat) and find no pigtail. So where is it?
Old 10-25-2018, 07:11 PM
houstonhdguy's Avatar
houstonhdguy
houstonhdguy is offline
I was going to below the left side left cover, but if you’ve already checked... Maybe it was removed for some weird reason?
Old 10-25-2018, 07:16 PM
Its time to ride's Avatar
Its time to ride
Its time to ride is offline
It should be behind the left side cover, or maybe the dealership profit bin?
Old 10-25-2018, 07:45 PM
chopper_man's Avatar
chopper_man
chopper_man is offline
Received 1,637 Likes on 969 Posts
Coiled up under left side cover. Part of the harness.
Old 10-25-2018, 08:08 PM
EasternSP's Avatar
EasternSP
EasternSP is offline
Received 23,033 Likes on 8,782 Posts
Start at the battery and trace the leads.
If there is only one cable to each post, you don't have a pig tail.
Old 10-25-2018, 08:37 PM
pcmc2's Avatar
pcmc2
pcmc2 is offline
Yep only one cable to each post. So I guess no pigtail. Bummer
Old 10-25-2018, 09:00 PM
14GuineaPig's Avatar
14GuineaPig
14GuineaPig is offline
It's part of the bike's harness on the 15 FLHTK so you will not find it connected to the battery, Look under the left side cover as stated in previous posts.
pcmc2 (10-28-2018)
Old 10-25-2018, 09:07 PM
RollaMo's Avatar
RollaMo
RollaMo is offline
As it rolled off the assembly line.
Under left side cover, item #6
pcmc2 (10-28-2018)
Old 10-25-2018, 10:15 PM
Hammz's Avatar
Hammz
Hammz is offline
Yes you do. The connector you're looking for comes from the factory under the left side cover & has it's own clip holding it securely fixed in place until someone removes it from its' mounting clip. It's shown in your owners manual. See item 6 in this figure:
It's wired into the Accessories circuit & fused via the 20A Accessories fuse.
RollaMo - you type faster than I do! ;-)
pcmc2 (10-28-2018)
Old 10-26-2018, 05:50 AM
EasternSP's Avatar
EasternSP
dang, just as I start to figure something out, they change it. Sorry for the bad information.
Quick Reply: OK...where is it?
