2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Police Seat on its way
Old 10-12-2016 | 03:26 AM
Jack the Lad's Avatar
Jack the Lad
How do you mount the seat shock? I know where it goes, but can't work out how to get the nuts on the bottom and tighten them, would the battery have to be lifted out?
Old 10-12-2016 | 04:05 AM
Chinashop bull's Avatar
Chinashop bull
Default Go Kong
Don't even bother with the stock airbladder or the mini shocker. Go to your local petshop and buy yourself a Kong dog toy. Gives you about 2" of smooth travel. Google it.
Old 10-12-2016 | 04:37 AM
Jack the Lad
I'm already aware of that, thanks.
Old 10-12-2016 | 06:03 AM
steelerdude1's Avatar
steelerdude1
I actually have the same question. My seat will be here today, so I guess I'll find out. I'll post up some pics on how it mounts once I get it on.
Old 10-12-2016 | 08:29 AM
danhahn's Avatar
danhahn
Yep, take the battery out. Mine had bolts that threaded up into the shock, not nuts. I don't think it would have been possible without pulling the battery. Easy to do though, at least on my '16.
Old 10-12-2016 | 12:48 PM
Candubrain's Avatar
Candubrain
Originally Posted by slapshot12
Are any of you riding with lower back issues? I'm curious how the police seat would feel on my back. On the stock seat, I use an Airhawk pad and a backrest, and I still get a little sore after a few hours sometimes.
I have a bad back and need to sit straight up. I use the police seat with a Utopia backrest, which mounts under the seat pan. I bought an Airhawk pad to supplement it for the Cannonball ride I did, but found I didn't need it, gave it to a buddy
Old 10-12-2016 | 06:07 PM
steelerdude1
I got the seat, and it's on now. Just to confirm, the shock bolts on from underneath. It is possible to get it on without removing the battery, but it's much easier to pull the battery.
Here are some pics, the install is pretty straight forward.
Bolts go in from the bottom
Took it out for a short ride, and so far so good, just need to dial in the shock.
I have the seat off and am giving a go at vinyl repair. The first step is done, and it has to dry / cure for 4 hours before I put the color and texture on..
roadkinglobo (10-17-2016)
Old 10-13-2016 | 02:21 AM
Jack the Lad
Excellent, thanks for the pics.
Old 10-13-2016 | 03:27 AM
stro1965's Avatar
stro1965
I found one locally yesterday and installed it last night (Kong method). Very pleased!!
Old 10-13-2016 | 11:45 AM
steelerdude1
The vinyl repairs are done, it's not perfect, but way better then a slash.
I also mounted up my backrest. Had to do some cutting and grinding to both the mount and the plastic piece that goes under the seat.
Also had to turn the bracket around to get a better angle. Just need to sand and paint it now.
Filled and preped
Color and grain added
Quick Reply: Police Seat on its way
