Auxiliary Light Power Switch Kit
I am sure this has been discussed before, but I couldn't find a clear answer so here it goes.
I have a 2016 HD FLHXS and I am looking to add additional LED Auxiliary Fog / Flood Lights onto my bike. I am trying to determine what electrical parts I need to make this happen.
I am thinking I need these parts:
Or can I go with these parts:
I've done some reading that have indicated when running auxiliary lights with the power switch kit that they won't stay on when the headlight hi-beams are on. To have the auxiliary lights stay on the system needs "flashed" and done by an HD service tech. If this is the case, what other options can I go with to add power to the auxiliary lights without having to "flash" the system?
Also, what would be the benefit to having this part:
Any insight would be greatly appreciated. Thanks!
this kit
71400106
and this
69200173
The second part number is for the module the controls the acc and aux switches and also includes the aux switch.
The first part number you listed is just for the module and the acc switches not the aux.
in the pic you can see the module in section I in the bottom left
![](https://cimg4.ibsrv.net/gimg/www.hdforums.com-vbulletin/1500x880/switch_814b0b64fcd9fa8b141a3793a49f64edd3a28906.jpg)
You could also go with this switch.
I use one for heated seat, one for leds, and one for led driving lights.
http://www.harley-davidson.com/store...09-7024802b--1
As far as wiring them the factory why they will still shut off with high beam so you'll need to have it flashed. If you look at the connector for the blinkers there is an extra spot for a wire. It is filled with like a white plug that you push out and slide the passing lamp wire through with a terminal. Right now I have mine pushed through and the wire folded along the plug so I could test them as I do not have all the parts to finish it 100%.
