2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Interior Tour Pack Lights
Old 04-13-2016, 09:46 PM
coujac's Avatar
coujac
coujac is offline
Originally Posted by acftgrunt
Well that puts some light on things...
Yes I didn't realize how bright they would be installing them during the day Oh well
Old 04-14-2016, 05:22 PM
bill1nat's Avatar
bill1nat
bill1nat is offline
Originally Posted by Baeseman1
Saw these LED pods, and had an idea.
Came in 2 sets of 4, but I'm only using 1 set.
Laid out, marked, and drilled the 4 pod locations
Not the most obvious, but you can see the hole in each corner
Little more obvious
Everything laid out. I removed & tapped into the 'cigarette lighter' for the power source and used a simple rocker switch.
Lights stuck in place and 12v power reinstalled
I used the dual-lock type fastener for the switch. I planned on mounting it to the 12v accessory, but that placed the switch really low and cumbersome to operate. Meh, the speaker port suits me fine.
Liner slid back in place.
In the garage with all the lights turned off. Ignition set to accessory to where the Electra Glo bag lights & tourpack side lights are on. These aren't the brightest LED's, but they do OK inside the black tourpack. Should be just enough light to keep the wife happy. Otherwise, I can run the other set on the lid without too much difficulty.
AWESOME JOB, That looks awesome!!
Old 04-15-2016, 11:03 AM
Baeseman1's Avatar
Baeseman1
Baeseman1 is offline
Stumbled on this site and looks like a fine choice for the same application. What I like about these lights better than the string I have, is you're not limited by the light pod spacing of the string. For ease of getting the tour pack liner in and out, I'd put 2 or 3 pucks on the front & 2 on the rear and avoid using the sides. That way the liner slides straight in and out. I have to be careful with the side mounted pucks as the liner goes in/out.
https://www.superbrightleds.com/more...#/tab/Overview
Old 04-16-2016, 10:45 AM
skieverything's Avatar
skieverything
skieverything is offline
..I tried to copy and paste an old post, didn't work....
Old 04-17-2016, 06:19 PM
motorcyclelockman's Avatar
motorcyclelockman
motorcyclelockman is offline
I put Auto Zone strip lights in mine. I used a magnetic switch to turn them off and on when the top is opened. Surface mounted all the wires using Black Gorilla tape. It has been on there for two years without a fail at all. I will try and get some pics after dark too.
Lights on when lid is open
Magnetic switch for off/on
This pod of lights are under the arm of the backrest to illuminate the inside of the saddle bag.
ON!
BobRed0965 (04-18-2016)
Old 04-17-2016, 08:30 PM
Oogie Wa Wa's Avatar
Oogie Wa Wa
Oogie Wa Wa is offline
Autozone, $14.99, I got them in white. I'm putting a couple on the tour pack lid and a couple in the trike's trunk. Pretty darned bright.
http://www.autozone.com/exterior-lig...?checkfit=true
Old 04-17-2016, 09:03 PM
digdug's Avatar
digdug
digdug is offline
No way in hell I'm cuttin up my 1400 dollar tour pack for some lights. How dark is it where you people ride and how much time do you spend searching inside the tour pack? Holy $hite .......don't your phones have an led light?
Old 04-17-2016, 09:21 PM
motorcyclelockman
Here are some pics of it after dark. My wife really likes it.
Old 04-18-2016, 12:52 AM
White Ice's Avatar
White Ice
White Ice is offline
$8 at Walmart, velcroed to the lid. Runs on 3 AAA, Touch operated, swivel head. Approx 6" long.
Old 04-18-2016, 06:05 PM
Baeseman1's Avatar
Baeseman1
Motorcyclelockman --- I really dig how you lit up the saddlebags!
And just when I thought I was done with the lights....
motorcyclelockman (04-18-2016)
Quick Reply: Interior Tour Pack Lights
