2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
oil mark on dipstick same hot or cold
Old 08-30-2015, 01:48 PM
baggerthree's Avatar
baggerthree
baggerthree is offline
6th Gear
Default oil mark on dipstick same hot or cold
ok i am confused...the oil mark is the same place on the dipstick whether the bike is hot or cold. bout 3/16" from "full hot on jiffy stand" line...when bike is cold the oil mark is really no different what gives? 2014 road king 5900 miles
Old 08-30-2015, 02:39 PM
wenterkin's Avatar
wenterkin
wenterkin is offline
Modern motor oils do not expand very much when heated. Assuming you allowed the oil temp to reach 180, it will most likely expand by less than 4%. If you go up to the 250 degree range, you may get as much as a 6% expansion. Based on 4.5 quarts of oil in you crankcase when cold, at most it will expand 1/4 quart. Moral of story; hot or cold, as long as in the "okay" range, you are good.
Old 08-30-2015, 02:47 PM
ZROADSTER's Avatar
ZROADSTER
ZROADSTER is offline
Question ?
With modern high performance synthetic motor oil .......does it not expand as much as a high performance DINO oil ?
Old 08-30-2015, 06:41 PM
p51bombay's Avatar
p51bombay
p51bombay is offline
What are you looking at? There's a mark for full hot on the jiffy stand or upright - none for cold. You shouldn't be using the FULL mark anyway.
Old 08-30-2015, 07:19 PM
ZROADSTER's Avatar
ZROADSTER
Cold & on the kick-stand at the half way mark . Then the same when fully warmed up & hot the AMSOIL still measures at the half-way mark on the stick . So what's up with that ? Obviously synthetic does not expand the way DINO oil does .
Just saying .
Old 08-30-2015, 07:28 PM
tesnevo's Avatar
tesnevo
tesnevo is offline
Manual generally will state that cold level shouldn't be more than halfway (in the middle) due to hot oil increasing column. That's what I've always gone by. Also checking on jiffy stand versus upright will generally merit the same results on our bikes.
Old 08-31-2015, 01:23 AM
jerryt87's Avatar
jerryt87
jerryt87 is offline
Yeah, mine doesn't move much either. I go for the halfway mark cold.
Old 08-31-2015, 07:52 AM
HazyHog's Avatar
HazyHog
HazyHog is offline
Just saying .
I use dino oil and my level always stays about the same, hot or cold. My Road King was the same way. It's normal
Old 08-31-2015, 07:56 AM
jpooch00's Avatar
jpooch00
jpooch00 is offline
Mine only rises about 2 "dots" when going from cold to op temp.
Old 08-31-2015, 08:11 AM
THE PEG's Avatar
THE PEG
THE PEG is offline
Welcome to the forum. Just ride and don't worry.
Quick Reply: oil mark on dipstick same hot or cold
