2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Ultra Limited to Street Glide Conversion
Old 10-25-2017, 06:59 AM
2015UltraLimited's Avatar
2015UltraLimited
2015UltraLimited is offline
Originally Posted by JHC210
Subscribed.
I am in the process of adding the quick detach to my Limited Low. Question: I don't like the look of the license plate holder in the conversion kit but would like to still keep the stock tail light, any suggestions? Do the tour pak connectors all lay under the seat when the tour pak is removed? Or are they rerouted under the frame/fender?
A new seat is certainly next, along with Ohlins, chrome, lid speakers, chrome....it never ends....
Thanks.
Here are a few pictures of my Limited Low with and without the tour-pak. I used the license plate holder and bent it forward. Also put on a chrome license plate frame around it as it just looked so cheap. When the luggage rack is installed, it does touch, so I put two layers of 3m clear bra under the luggage rack where the plate touched.
With the different seats, the wiring fits under the Ultra and Street Glide seat with the tour pak removed. It does not fit under the solo Mustang Low rider seat, but I only use that seat when the tour pak is on the solo mount bracket.
  #32
Old 10-25-2017, 09:47 AM
BigMike's Avatar
BigMike
BigMike is offline
Received 1,577 Likes on 678 Posts
This is just my opinion, but in order to get the right look, you need the blank fenders without the lights. Otherwise it just looks like a stripped down Ultra.
  #33
Old 11-02-2017, 06:08 PM
Axegrinder's Avatar
Axegrinder
Axegrinder is offline
How I did mine.
Attached Thumbnails Ultra Limited to Street Glide Conversion-23192298_10210664327464615_834752922_o.jpg
  #34
Old 11-03-2017, 11:13 AM
Uberjason's Avatar
Uberjason
Uberjason is offline
Default Here's mine. 2016 Stripped down a bit
  #35
Old 11-04-2017, 12:42 PM
Dsm Limited's Avatar
Dsm Limited
Dsm Limited is offline
Moderator
Received 9,198 Likes on 3,179 Posts
Heres mine
Ultra mode
Street glide mode
Solo ultra mode
  #36
Old 11-04-2017, 09:41 PM
offthewall's Avatar
offthewall
offthewall is offline
Here is my 2014 Limited in “Street Glide” mode.
Stock Street Glide seat. HD removable Tour-Pak kit. H-D Electra Glo™ Keystone Auxiliary LED Run/Brake/Turn Lamps.
Piloto (01-16-2018)
  #37
Old 11-05-2017, 06:28 AM
JHC210's Avatar
JHC210
JHC210 is offline
Looks great. Need to find a Street Glide stock seat.
  #38
Old 11-05-2017, 08:03 AM
Beaux's Avatar
Beaux
Beaux is offline
2018 CVO seat and Road King tail light bar ............
Attached Thumbnails Ultra Limited to Street Glide Conversion-img_5309.jpg   Ultra Limited to Street Glide Conversion-img_4766.jpg
  #39
Old 11-05-2017, 09:09 AM
Gunnysgt's Avatar
Gunnysgt
Gunnysgt is offline
On my first conversion I got a simple lay back plate holder on EBay for about $20. Had to drill three holes in the fender to mount it but it fit perfectly whether the tourpak was on or off. Liked the lay back look better as well. As for hiding all the cables. you can bundle them up and hide them under the seat but it does help to have a seat that will take a backrest since there is a big hole underneath to stuff the wires in. I'm about to convert my new CVO with a detach kit.
  #40
Old 11-05-2017, 09:23 AM
offthewall's Avatar
offthewall
Look around on eBay and here. There are always new take offs for sale. That's how I got mine.
Quick Reply: Ultra Limited to Street Glide Conversion
