tour pack for a street glide
#41
The tour pak brake light running light and turn signal conversion kit harness is 69200042A that fits 97-13's hope that's what you're looking for. The number for 14s and later is 68000123A. They are called conversion kits page 736 of the 2016 P&A catalog from Harley!
![Smile](https://www.hdforums.com/forum/images/smilies/smile.gif)
#43
HD chopped and lowers added over winter. Need to find a new seat for use when TP is being used. TP sits too far back and wife slides off back of seat. TP is mounted as far forward as possible.
What seat has the same rider position, but has the larger pad like the Ultras for the passenger? Wanting a stock HD seat if possible
![Name: IMG_3636_zps9qcxpvjj.jpg
Size: 268.7 KB](https://www.hdforums.com/forum/attachments/2014-2023-touring-models/523749d1501309182-tour-pack-for-a-street-glide-img_3636_zps9qcxpvjj.jpg)
Last edited by CVO SG; 04-05-2016 at 08:31 PM. Reason: Thumbnail out, Photobucket in
#44
Edit: Found the link to the custom dynamics harness. http://www.customdynamics.com/loadequalizer.htm 2nd up from the bottom. Part number MBR-BCM. To my knowledge, that should just plug in at the tri bar, and gives you all your leads so you do not have to splice everything. From there you would just make up your own harness up to the tourpak. Depending on how handy you are, it would be pretty simple. If i would have found this before I took it to the dealer, I probably would have done it myself. Only pain in the *** about it is there is NO TEMPLATE for how to mount the light on the tourpak. Not even something my dealer had.
As for the antenna, I have the hidden antenna in the fairing.
That is not what he was looking for. That is to make your turn signals on an ultra into brake lights as well.
jiml53 (04-08-2016)
#45
I modified harness part number 69200772 to work. cut the three wire connector off and then installed a 6 plug. would have to find the part numbers later. P&A should be able to look them up. just need some extra wire, the pins, and the connector. then it plugs into the light harness under the seat.
#46
#47
I have the exact same cycle and it appears you have it set up for 1 up with the option for 2 up riding, depending on were you position the tour....
could you PM me the parts listing you had for this set up, I want mine to look exactly like yours.....thanks in advance
![Icon Headbang](https://www.hdforums.com/forum/images/smilies/icon_headbang.gif)
oh and did you do the wiring yourself, and got any more pics to share
#48
could you PM me the parts listing you had for this set up, I want mine to look exactly like yours.....thanks in advance![Icon Headbang](https://www.hdforums.com/forum/images/smilies/icon_headbang.gif)
http://www.harley-davidson.com/store...-mounting-rack vs http://www.harley-davidson.com/store...-mounting-rack. The wiring was all done with HD parts, plug and play.
Here are a few pictures of solo and two-up
#49
