2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
New 2014 & 2015 Fog Lamp Wiring
Old 01-22-2015 | 12:49 PM
DC2009EGUC's Avatar
DC2009EGUC
Default New 2014 & 2015 Fog Lamp Wiring
I have one quick question for those that have installed the new LED fog lamp kit part# 68000090 or 68000092 (chrome & black)...Is there a special connector to plug/interconnect part#69201109 (LED fog lamp wiring harness) to part#71400106 (Auxiliary Power Switch Kit - Fairing Mount)?
It seems that the only way to interconnect these two wiring harnesses, is to splice 69201109 into 71400106 as I have searched all over HD's P&A online and came up empty handed...I have attached pictures of what I am talking about and would like to get some confirmation if this is the only way to interconnect or is there a special adapter...thanks...
Attached Thumbnails New 2014 & 2015 Fog Lamp Wiring-69201109.jpg   New 2014 & 2015 Fog Lamp Wiring-71400106.jpg   New 2014 & 2015 Fog Lamp Wiring-fog-lamp-connector.jpg
Old 01-22-2015 | 05:09 PM
HEYENG's Avatar
HEYENG
Looking to do the same thing just ordered the service manual hope I can figure out the wiring
Old 01-22-2015 | 05:38 PM
UltraSteveUSAF's Avatar
UltraSteveUSAF
It's all plug and play there is 3 harnesses I think I had to order. 1 to the switch, 1 to the harness under the left cover and 1 to the lights. It still hasn't come in but I can go by the dealer and get a list of the part numbers tomorrow.
Old 01-22-2015 | 06:28 PM
DC2009EGUC's Avatar
DC2009EGUC
Well based on my research, it may not be all "plug & play"...if you look at the images the part#69201109, this is the harness that is supposed to connect to the new daymaker fog lamps. Part#71400106 is supposedly, the harness that will allow you to control the on/off power to the fog lamps "independently" from the stock passing lamp switch. However, if you look at both parts on each end, the male & female plugs are not the same type, not no way to plug or make "plug & play" compatible. I have in my hand both harnesses and been scratching my head all day trying to figure out how to interconnect...
Harley's parts catalog & online shows no interface cable that will mate the the connector. About the only way to do this is to splice & solder or crimp or use postsi taps...Kinda disappointed at this point, perhaps, Harley-D is still manufacturing the correct part...
aklowrider (04-11-2016)
Old 01-23-2015 | 06:49 AM
Gunnysgt's Avatar
Gunnysgt
I used the wiring from this kit to run my CD caliper lights. It WAS plug and play, only thing I didn't like is the lights WILL come on with your passing lamps. I wanted mine to come on separately. I wanted to be able to chose between the fog lamps and passing lamps. I ended up wiring them myself to the Aux switch already on the RK. With those switched on linked, I would be running 7 lights in front, fogs, passing, headlight and signals. In Pa and some other states, that's illegal to run than many lights together.
epson390
07-14-2017 02:13 PM
fiddypal
Milwaukee Eight (M8)
17
05-29-2017 07:47 AM
mstrobes
06-27-2015 01:09 PM
Bigg Lou
05-09-2014 02:18 PM
CroGlideUltra
01-05-2014 07:23 PM
Quick Reply: New 2014 & 2015 Fog Lamp Wiring
