2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Old 02-18-2015, 03:28 PM
How-Tos on this Topic
Last edit by: IB Advertising
What oil is the Best?
Any Quality 20/50 oil will do with a change every 3000 or so. Read more at:Oil
Read Full Discussion below
Print Wikipost
What Oil Is The BEST
Old 01-10-2015, 10:40 AM
alarmdoug's Avatar
alarmdoug
alarmdoug is offline
There is an oil and lubrication section in this forum.
Bottom line ANY quality, name brand 20/50 oil.
I use conventional oils and change by 3000 miles. Right now Harley 360 but Valvoline is a top contender. Harley and Valvoline oils produce fine wear numbers against some of the most expensive oils. So much so your splitting hairs on which one is "better"
Other great oils, syn or conventional Valvoline VR1 or their motorcycle oils, Mobile 1, Castrol and without question all Amsoil products, even though I don't use them, I give Amsoil a lot of credit for a fine product with real product testing comparing them against all the others.
I prefer conventional because I change oil a couple times a year and the wear numbers of the oils I mention are just as good and sometimes better then syn. Amsoil again, is a standout.
I still use Primary + in the trans and primary.
  #32
Old 01-10-2015, 11:20 AM
offthewall's Avatar
offthewall
offthewall is offline
Well, just to be different in this thread, I'll just tell ya what I use. Harley Syn3 in all three holes. I change it once a year. I've never had a problem in 15 years of using it.
I'm not of the opinion that the MoCo is out to get us, is incompetent or ruin our engines just to create out of warranty work. That's what they put in their most expensive bikes (CVO's), so that's what I use.
  #33
Old 01-10-2015, 11:47 AM
Steve On 3's Avatar
Steve On 3
Steve On 3 is offline
Another vote for just keep it changed. My 95 Ultra I put 168k miles on with Castrol GTX 20w50 dino oil changed at 2500 miles. never anything but tune ups. My twin cams have all had synthetic, usually syn 3 with formula + in primary and mobil 1 synthetic gear oil in tranny.
  #34
Old 01-10-2015, 11:51 AM
dribble's Avatar
dribble
dribble is offline
Originally Posted by Norms 427
Here's all u need to know about oil:
Oil in crankcase = Good
No oil in crankcase = Bad
This..... is all anyone needs to know about oil in their bikes.
  #35
Old 01-10-2015, 12:22 PM
RushKing14's Avatar
RushKing14
RushKing14 is offline
My recommendation on what oil to use? The slippery kind works best I have found.
  #36
Old 01-10-2015, 07:43 PM
CSMHOG's Avatar
CSMHOG
CSMHOG is offline
Yep, just stay on top of your changes and be sure to use the right service rated oil.
  #37
Old 01-10-2015, 09:08 PM
DannyZ71's Avatar
DannyZ71
DannyZ71 is offline
Originally Posted by Iceman24
ANYTHING's better that crap HD Synth so your options are only limited to the thousands of oil threads you can muster-up on an oil thread search.
I suppose you have some scientific evidence that HD branded oil is crap? How do you know it's not Mobil 1, or an even better oil, rebranded??
Please post any proof you have of that?
  #38
Old 01-10-2015, 09:23 PM
californiafatbob2013's Avatar
californiafatbob2013 is offline
Default My 00.2......
I think when we are changing oil so often anyways a good quality will do the job well.
I have now done my 1,000 mile fluid change and will be running:
Valvoline 20w/50 MC - Conventional in the engine compartment ( I think a good conventional is better for the valve train and produce's very steady oil pressure, with less valve train noise) Engine sounds real good with this oil.
Mobil 1 LS - 75w/145 - Synthetic - In the gear box (Always been stuck on
Mobil 1 when it comes to the gear box)
Harley Trans/Primary Fluid - In the primary (Like I stated above)
I think picking what you want to run, put it in, run it and stick with it.
Call it superstitious if you want, but I don't believe in mixing oils - JMO.....
Live Free = Ride Free.............
  #39
Old 01-10-2015, 09:41 PM
MikeyTX's Avatar
MikeyTX
MikeyTX is offline
What ever is on sale at 7-11
  #40
Old 01-10-2015, 10:00 PM
dgdamore's Avatar
dgdamore
dgdamore is offline
Quick Reply: What Oil Is The BEST
