2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Daymaker Reflector LED Fog Lamps & Wiring Harness
Old 09-30-2014 | 08:29 PM
scooterkid's Avatar
scooterkid
6th Gear
Default Daymaker Reflector LED Fog Lamps & Wiring Harness
Hi, I am trying to figure out where the Four-Way Auxiliary Lamp Connector is on my 2014 FLHTK Limited? The attached pictured instructions say to disconnect this connector and connect this harness between the two separated connectors. The harness is part number 69201109.
I want to add the new for 2015 LED Fog Lamps. Anyone that may have any information on where this connector is would be very much appreciated. Thanks…
Attached Thumbnails Daymaker Reflector LED Fog Lamps & Wiring Harness-wire-harness-page-1.jpg   Daymaker Reflector LED Fog Lamps & Wiring Harness-wire-harness-page-2.jpg
Old 09-30-2014 | 09:21 PM
Londonbike's Avatar
Londonbike
The service manual states that this connector is located inside left or right front turn signal/aux lamp support(with fairing). Hope this helps
Old 10-01-2014 | 08:53 AM
GeneseeGap's Avatar
GeneseeGap
Thinking those are different purchase as I ran across those on the HD website the other day.
Old 10-01-2014 | 12:26 PM
J929626's Avatar
J929626
I believe that you need to add a switch. Part Number 71400106 should work.
Old 10-01-2014 | 05:53 PM
Mister Breeze's Avatar
Mister Breeze
Can't help with the hookup, but anxious to hear how you like them.
Considering myself for that dead spot between the auxiliary spots and high beam. Also not much room between the highway pegs and fog light mounts. Hoping they can be adjusted up some.
Old 10-01-2014 | 05:54 PM
Yukon42's Avatar
Yukon42
I just want to know if the damn things are worth $400!
Mister Breeze
Yeah that too! But closer to $500 after the harness and mounts. I would only consider on sale.
Old 10-01-2014 | 07:09 PM
scooterkid's Avatar
scooterkid
6th Gear
Default DayMaker LED Fog Lamps/Wiring Harness
Thanks for all the reply’s. I think I figured out that the connecter I need to separate and connect the wiring harness between is actually inside of the bracket that the Driving Lamps and Turn Signals are mounted on. I have been reading into the instructions to deep. Not sure just yet but I assume that these extra 2 ½” DayMaker Highway Bar mounted Fog Lamps will be on with the passing lamps which I had programed to stay on with the high beam. It’s kind of confusing passing lamps, fog lamps? Anyway I will let you know how they work out and if these lamps fill in light as the one person mentioned. I did get them cheaper than $395.95 and the only other thing you need is the wiring harness which is like $25.00 and the mounting bracket that mounts them to the Highway Bars, I think that was $49.95. You don’t need to purchase any auxiliary switches. They seem to be made very well and have some weight to them. I purchased the three parts over like 3 paychecks as stuff isn’t cheap as we all know.
Hope to get them installed over this weekend and will let you know what I think of them. For those of you not sure of the LED lamps I am talking about see the attached picture. Thanks again…
Attached Thumbnails Daymaker Reflector LED Fog Lamps & Wiring Harness-hd-led-light.jpg
Old 10-02-2014 | 05:13 AM
Mister Breeze
Anxious to hear how you like them. Black Friday sale at a local dealer will help with the cost. 30% most years.
Old 10-02-2014 | 05:42 AM
oldpanzer's Avatar
oldpanzer
I was researching doing the same thing however the cost is prohibitive to me $399.95 for the lamps is not equal to the technology in the lamp. I am looking into using the using the Harley chrome mount and a set of led lamps off of Ebay.
Quick Reply: Daymaker Reflector LED Fog Lamps & Wiring Harness
