Multi-Fit Parts and Accessories For those Parts and Accessories that fit more than one model of Harley Davidson.
Harley Digital Gear Indicator Gauge 70900078
Old 02-16-2014 | 02:41 PM
jmat1980's Avatar
jmat1980
Default Harley Digital Gear Indicator Gauge 70900078
$100 FREE SHIPPING
Up for sale is a Harley Davidson OEM Digital Gear Indicator. Gear Indicator was used for about a year and taken off the bike when the bike was sold. This auction includes the optional aux switch which must be purchased separately when bought new...included for FREE!! (aux.switch can be removed and filled with blank plate, also included). This gear indicator is plug and play, very easy to install!! All instructions and box are included. Gear indicator mounts to right side of handlebar and replaces stock cover for a flush OEM fit. See link below for fitment. Retails for over $200!!!
Harley-Davidson® Digital Gear Indicator 70900078 What gear am I in right now? Eliminate the guesswork with a Digital Gear Indicator. Conveniently located on the handlebar for line-of-site viewing, the bright LED display is easy to read with a quick glance. When the clutch is "out", the display indicates the current gear, or a large "N" when the transmission is in the neutral position. Easy to install, this plug & play Gear Indicator requires no wire splicing or complicated programming. A built-in photocell automatically adjusts the display for improved visibility in direct sunlight, and dims the display at night to reduce distraction. The complete kit includes a self-contained LED and control module, control housing, wiring harness and required mounting hardware. Switch housing can accommodate one additional auxiliary switch
Will fit the 2013 model year for the following bikes. For additional fitment go to http://harley-davidson.com/store/dig...10-70900078--1
Street Bob FXDB
Super Glide Custom FXDC
Fat Bob FXDF
Wide Glide FXDWG
Sportster 1200 Custom XL1200C
Seventy Two XL1200V
Forty Eight XL1200X
SuperLow XL883L
Iron 883 XL883N
Road King FLHR
Road King Classic FLHRC
CVO Road King FLHRSE5
Electra Glide Classic FLHTC
Ultra Classic Electra Glide FLHTCU
CVO Ultra Classic Electra Glide FLHTCUSE8
Tri Glide Ultra Classic FLHTCUTG
Electra Glide Ultra Limited FLHTK
Street Glide FLHX
Road Glide Ultra FLTRU
Road Glide Custom FLTRX
CVO Road Glide Custom FLTRXSE2
Night Rod Special VRSCDX
Old 02-16-2014 | 02:47 PM
jmat1980's Avatar
jmat1980
Photos...
Old 02-16-2014 | 02:59 PM
shrini23's Avatar
shrini23
The reviews on the HD site says that when you pull clutch in, it does not show what gear are you on? Is that true...
Another guy says in the review as "Unreliable" as all eight segments were on..
Since you had it on your bike for almost a year..what is your take on it...
I;m interested and wanted to get a first hand opinion from a user
Old 02-16-2014 | 04:53 PM
RJHD's Avatar
RJHD
PM Sent
Old 02-16-2014 | 06:00 PM
shrini23's Avatar
shrini23
2nd in line..
If RJHD passes it
Old 02-16-2014 | 07:56 PM
jmat1980's Avatar
jmat1980
It does not show the gear when in neutral or when you pull the clutch lever in. Other than that it is reliable, and has never shown me a gear incorrectly. When in neutral or with the clutch lever pulled it only shows a dash...
Someone pmd me and asked what the aux switch was for...it van be for whatever u want. There are two wires that come from the switch, one for 12volt and one for whatever you want to control. In my case I disassembled a garage door opener and connected the switch to that. When I pushed the switch on it activated the garage door opener...
Old 02-16-2014 | 08:41 PM
PARoadking1's Avatar
PARoadking1
If this is like the new speedo with the built in tach, it determines the gear by the speed and rpm of the bike. That is why you don't see a gear at idle.
Old 02-17-2014 | 04:49 AM
dyolfknip's Avatar
dyolfknip
Stock or HD displays do not show gear when clutch is in.
Old 02-17-2014 | 11:16 AM
shrini23's Avatar
shrini23
PM Sent with info/details
Old 02-17-2014 | 08:20 PM
rwb1's Avatar
rwb1
3rd in line if it doesn't sell....pm sent
Quick Reply: Harley Digital Gear Indicator Gauge 70900078
