Twin Cam Heads TC88/TC96
ALL HEADS ARE BLACK WITH SILVER HIGHLIGHTS!
For Sale Harley Davidson heads that will fit on TC88 and TC96 engine configurations.
1 set of stock heads from 2005 road king, very good condition $350 or Best Offer. Perfect for head porting projects!
1 set of stock heads from 2003 classic, very good condition $300 or Best Offer. Perfect for head porting projects!
1 set of ported heads, 1.94" intake valve, 1.63" exhaust valve. beehive springs, set for .600 lift. castings are stock. 5200 miles on them. The heads have been ported for Torque & HP and milled for 73 cc combustion chambers. Compression releases installed. $600 or Best Offer.
Email for more info or to make an offer.
Thanks
Producer
Thanks
Producer
Lee's Speed Shop. Savage Minnesota. Ps...they have compression releases too. In a 95" motor with flat top pistons, the static compression is about 10.6:1, so I would recommend two things, either use a long duration HP / Tq cam or get the combustion chambers machined to match the cam, piston and engine displacement that you've chosen.
