will this work in my 02 95?
I'm interested? What injectors are you selling?
Yes, it fits 01-05 Delphi fuel injected bikes and would be a good match for your 95". I was running it on a 10.5 comp 98". The injectors (included) are stock injectors which were sent to Marren to be cleaned and flow matched.
What is included in Marren Fuel Injection’s Injector Service?When an injector arrives at Marren Fuel Injection, it is tested to see if it functions properly. Its flow rate and fuel spray pattern are checked to determine if it is working properly, and its impedance is tested. The injector is then cleaned and flushed, and any serviceable parts, such as o-rings, seals, and plastic pintle caps, are replaced. After this, the injector is re-tested to note any improvements in performance due to the service. All of the measurements and information gathered during testing is recorded on a computer analysis sheet that is shipped to the customer along with the injector. When multiple injectors are provided, the injectors are also checked against one another to make sure that they are matched in performance.
