ThunderMax w/auto tune P/N 309-360 $450.00 Shipped
This was purchased 04/28/2010 with a factory three year warranty and was taken off my 2010 Fat Boy in excellent condition.
Also comes with:
#309-324 - ThunderMax® Pigtail Harness $18.95
This pigtail harness allows a second port for the communication cable connection to the ThunderMax®. It is installed to the bike's wiring harness at the 36-pin ECM connector (connection requires harness plug disassembly; two terminated wires are inserted into two unused ports in the 36-pin connector, and a ground wire added). Handy for motorcycle models with tight clearances around the ECM such as Dyna®, Softail® Rocker® and 2002-2005 V-Rod® models. Requires ThunderMax® ECM with serial number 114000 or higher (produced beginning August 2008). Will not work on previous model ThunderMax® ECM's.
I do not have the SmartLink CD (didn't work anyway) but you can download the software from Zipper's website.
Also comes with:
fuelmoto
Fuel Moto / Jackpot Mufflers
03-16-2010 11:26 AM
