Ported Polished Heads TC
Lower price Ported Polished Heads TC
SOLD SOLD
NEVER MOUNTED OR USED::
I have a pair of professionally ported and polished heads. Will fit 1999- 2006 twin cam. They were ported and polished set up for velocity. Stainless steel valves intake is 1.900 and exhaust 1.6. Competition cams valve springs will handle up to .600 lift. Heads were CCed at 82ccs and surface milled .020 which will raise your compression about 3 tenths higher. (Example if pistons are 9.5 with these heads it will raise it to 9.8 compression ratio) There is also a matching ported Manifold.
These heads will be a huge improvement over stock and must have for any big bore or cam upgrade. These are 1000.00 heads. I was going to put them in my Wide Glide but traded it for a 2007 Ultra Classic and they will not work on the 2007 or newer engine due to valve angle i was told. So my loss is your gain. I rather sell them so they can be used than let them continue to sit in my garage on the shelf!!
525.00 Shipped LOWER PRICE 500.00
525.00 firm Shipped
525.00 firm Shipped
