Kisan Pathblazer Headlight Modulator P115W-S
Item is SOLD! Thanks!
$65, includes shipping to continental US. The photo attached to this post is the actual item.
Used this unit on my 2008 Electra Gllide Ultra Classic. Works perfectly, very simple plug and play installation. Includes detachable daylight sensor.
Buy this from me so I can afford to purchase a new one for my 2011 FLTRU with two headlights!
Some info from the Kisan website (www.kisantech.com):
P115W-S unit is designed for 3-pin H4 or a Japanese H7 2-pin style headlamps. It's 1.25" (32mm) round, and requires NO ADDITIONAL SPACE after it's plugged on the back of the bulb.
pathBlazer circuit modulates the hi-beam current - from 100% ON to about 17% OFF. This is accomplished by using a p-channel MOSFET, which is inherently safe. The MOSFET is designed to fail in the ON state. For additional safety, the circuits DO NOT utilize the lo-beam whatsoever!
P115W-S comes with a detachable daylight sensor, which simply plugs into the pathBlazer. The daylight sensor functions as a switch; it stops modulation when it cannot see enough daylight. Since the internal circuitry is controlled by a microprocessor, it allows for customizable features.
tommarbru
09-05-2012 04:20 PM
blazer, classic, davidson, harley, headlight, installing, kisan, modulator, motorcycle, p115w, p115ws, path, pathblazer, reviews, ultra
