SE 251 cams 07 and newer w/chains
Above ref'd cams 150 dollars, 3000 miles in 2 years, don't laugh!!!
Also SE quick install pushrods with the tubes that came with them, installed and used with the cams on the same bike, 75 dollars.
********Both are sold********
SE 251 cams PN#25466-06 Fits '06 and later Dyna and '07 and later Softail and Touring models. This is the description straight out of the '09 SE catalog that I have.
These cams (251) has now being only made to fit 99-05 Dyna and 00-06 Softail and 99-06 Touring with the 259e's being the replacement for the 251 in the 06-later Dyna and 07 and later Softail and Touring.
The push rods come with the tubes but not the o-rings as I needed to re-use them for my new push rods. They are the quick install types but not the tapered type. Some guys like different styles for different reasons. They worked fine but my new mechanic wanted me to try the tapered due to the extreme valve train noise I was getting but the noise was due to the valve springs hitting the rocker boxes, Non-stock heads, non-stock springs, stock rocker boxes and this should have never happened but thats why I have a "new" mechanic.
Couldn't get the other cam pic to load.
