Multi-Fit Parts and Accessories For those Parts and Accessories that fit more than one model of Harley Davidson.
SE 103" Flat-Top Pistons/TPE CR'S/103" Top End Gasket Kit
Old 08-04-2010, 08:27 AM
troop's Avatar
troop
troop is offline
Default SE 103" Flat-Top Pistons/TPE CR'S/103" Top End Gasket Kit
Pretty much decided I'm going with a cam only install so I'm going to sell my pistons, compression releases and top end gasket kit initially as a SET.
Get a start on your 103" build and add cams of your choice. Kit includes:
1.) Harley-Davidson SE 103" flat top piston kit. Piston numbers are 21989-07 and are from separated 103" big bore kit #29905-07. Includes pistons/rings/clips and pins. MSRP approx $174.95 if bought separately.
2.) Harley-Davidson top end gasket kit (also separated from big bore kit). Part #17052-99B Msrp approx $79.99 if bought separately. Unopened from the way I purchased it.
3.) Total Performance Engineering manual compression releases. These are the custom style that allows you to put on your own threaded cap. These list for $28 each.
http://tpeng.com/compression_releases.php
I will box up the set and sell for $220/shipped to lower US. Paypal accepted.
Old 08-05-2010, 06:25 PM
troop's Avatar
troop
troop is offline
$215/shipped lower 48
Old 08-06-2010, 12:59 PM
troop's Avatar
troop
troop is offline
** Sold**
graysbodyshop
05-10-2018 01:01 PM
graysbodyshop
Touring Parts
01-28-2015 12:32 PM
evil451
05-16-2014 01:24 PM
p51bombay
Dyna Parts
12-02-2012 05:43 PM
equandt
12-26-2011 10:16 PM
Quick Reply: SE 103" Flat-Top Pistons/TPE CR'S/103" Top End Gasket Kit
